Question about Samsung Computers & Internet
Samsung monitor 2253
We purchased the above monitor today and tried to hook it up to a pentium 4 computer. The monitor came on but inside of being full screen at 21.6 inches its just 17 inches or so. How do we get the monitor to go full screen
  • 89 Answers
Adjust the settings of the video of your computer through the display settings under the control panel. you can try to set it as 1024x768 resolution or higher.
Posted on Aug 24, 2008
Can 1gb ram supports tally software with atom processor
System Requirements
  • Recommended Hardware Requirements for Tally 9
  • Pentium 4 and above or equivalent
  • 256 MB RAM
  • Minimum Disk Space: 40 MB
  • Operating System Software: Microsoft Windows 98/ME/NT/2000/XP
Hence, your system would definately support Tally.
Hope it helps! Good Luck!
CreativeTECH
Mar 19, 2011 | Samsung Netbook / Intel Atom Processor /...
The Digital wire on the moniter for Samsung Syncmaster 2253 LW is not working anymore. Right now i have to use the old style moniter plugs.
If the old style connector (VGA) is working, you can use that. For single monitors under 24" wide, the difference is not noticeable.
Mar 04, 2010 | Samsung SyncMaster 2253LW Monitor
I HAVE A SAMSUNG 2253 22' LCD MONITOR,POWER LIGHT FLASHES,AND SCREEN STAYS BLACK ,IT TRYS TO LIGHT UP ,BUT STAYS BLACK,MY OLD TINY 15' LCD WORKS FINE ON THE SAME COMPUTER,MY 22 USED TO WORK FINE??????
A flashing power light like that indicated a blown power supply. Your monitor should be under warranty with Samsung. Check the mfg date on the back sticker, if it is less than 3 years then contact Samsung. If it is out of warranty then contact us at tech@ccl-la.com and we can get you the info you need to do the repair yourself.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | Computers & Internet
Newbie question
Should just be able to go to manual settings, that will override the auto setting.
Dec 14, 2009 | Samsung SyncMaster 2253LW Monitor
Distorted shrunken picture
hi
reduce the resolution to a bit lower and the refresh rate to a nominal 60hz and things should get back to normal
my hunch is u r using a slightly high resolution and refresh rates
but before that try the buttons on the monitor to see if expanding the image sideways or top and bottom would help initially
cheers
pls rate if this was any help
Mar 31, 2009 | NEC MultiSync FE700 17" CRT Monitor
SyncMaster 2253 BW Samsung
Hi...there,
Have try open your monitor on screen display (OSD) and used the auto adjust settings.
Oct 13, 2008 | Samsung SyncMaster 2253BW LCD Monitor
Monitor light blinks
have you tested the power supply connection feeds? test each connector I think you will find your power supply has failed on either the 5 volt or the 12 volt side more than likely 5 volts are down' the agp adapter needs 5 volts to run. since you have changed out every thing else I would replace that or test your dads power supply in your computer, that should do the trick
Apr 28, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Computers & Internet Logo
174 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
