Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
I connect to wireless router but cannot connect to internet
I installed a Belkin (F5D7050) 802.11a/g/b Wireless Adapter on my desk top computer, The software says I am connected to the network, but when I launch explorer it says it cannot find the server, I tried everything. any ideas..
I got a belkin router and the adapter and spent a lot of money only to find out that the belkin product is total junk. Best get another brand that works!
Posted on Sep 07, 2008
    Sergeant:
    Champion:
  • 236 Answers
Can you connect to the internet if you use a ethernet cord to connect directly to the router?
If so , check the password you provided to connect to the network.
Posted on Aug 24, 2008
We've tried the belkin play wireless usb adapter in 2 laptops with xp pro and it wont connect the signals great it says the card is working properly but it just says it cant connect i've had this same...
Have you got two wireless icons down on the right by the clock. As it may be using the belkin wireless manager to control the device rather than the windows version.
Mar 11, 2011 | Belkin Play Wireless USB Adapter (F7D4101)
Laptop died and now I cant connect my desktop with the belkin usb adapter. It just keeps saying aquiring network address.
Use the Ethernet cable to verify the router or modem is working and connects to the Internet. If so, then check your wireless adapter in the desk top through device manager - it should detect the Belkin. Also, verify you are entering the correct WEP keys to access the wireless connection to the router or modem - sometimes it gets typed in wrong.
Feb 19, 2011 | Belkin (F5D7050) 802.11a/g/b Wireless...
Connection wireless adapter to laptop dell
Open up PC, Plug it wireless network into a PCI slot, turn on PC, the network device will be recognized and ask for drivers, you insert the CD/DVD that came with it, or use the software you downloaded from Belkin web site and install the WiFi card.. Run the Belkin software and it is installed. reboot PC, put case side back on.
Mar 02, 2010 | Belkin (F5D7000) 802.11g/b Wireless...
Hi can you direct me to any isalation software for belkin wireless G network adapter F5D001.i have drivers but need software that has the utility software for istalling.
You need the Version number of the Adapter
Goto www.belkin.com/support
On the top right you will find the Search
There type F5D7000
On the Results click the Link that Has the Drivers
Download the Drivers for the Version of your Adapter
Install the Drivers
Nov 26, 2009 | Belkin (F5D7001) 802.11g/b Wireless...
I have D-link 625 Wireless router but i try to connect on my desk top computer by Belkin G wireless USB network Adapter 5012. If i put password on WSK-Personal ( on wifi password setting) is not going...
Check your settings on your wireless setup and make sure the adapter on your computer is set to Security Type: Shared. That is the most over-looked stumbling block.
Nov 15, 2009 | D-Link DIR-625 (790069292637) Wireless...
DESK TOP TO WIRELESS CONNECTION
First make sure you have the correct drivers installed, go to the Belkin website to get the latest drivers for your device.
Next make sure that your router is set to broadcast, and that is in Wireless G mode. You can find that information at the router manufacturers website.
Apr 15, 2009 | Dell Dimension 2400 PC Desktop
Belkin F5D7000 Wireless Network Adapter problem
is the driver and adapter is installed properly?
It seems if your connected and saying limited or no connectivity.
Check this settings to your router:
Turn off the MAC filtering
Disable the wifi-protected setup
Try to change the channel of your router from 1, 6 or 11
Then check if you got the same problem as before?
Note: Try to use the updated driver of the adapter so that you can use the features that is been added to the software.
Mar 08, 2009 | Belkin F5D7000 802.11g/b (NWBLKF5D7000)...
Wireless adapter used to work, then stopped, then worked again, now can't be detected...
you mean that the adapter is not being recognised by the pc as a usb device, this adapter works better on a usb2.0 port, not as well on a usb1.0 port, depending on how old your pc is, try other ports., but you must uninstal the belkin driver from add/remove programmes, then install the driver again and inset adapter in a different usb port than before.
the adapter should then be found and click install driver automatically, but leave the cd in the drive as it normally picks the driver up again from the disk on it's own even after installing it yourself.
When installed i would recommend using windows wireless zero configuration (windows own software) instead of the belkin software, to do this right click on the network icon and select enable WZC (windows zero config), as this is a more stable programme for connecting your adapter signal to the router
Personally Belkin is poor in my opinion, netgear has better software and drivers, but it's belkin you have, so follow the above and it should be ok.
Sep 09, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
D-Link wireless router and Belkin Wireless G USB Network adapter
Set your wireless network as a preferred network and to automatically connect to it. Also set it at the top of the list so that it takes precedence. If you continue to get conflicts, change the channel of the router.
Mike
Oct 31, 2007 | Computers & Internet
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
187 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
