Question about Sony KDF-E42A10 42 in. LCD Television
Screen burn in?
I have a rear projection lcd that has started showing two vertical blue/pink light lines starting at the bottom of the screen tappering off about half way up the screen. The line is distinct at the outside and fade going in toward the center of the screen. The lines start at about where the black bars are when viewing 4:3. Not bad in 4:3 but very visible in 16:9.
    Scholar:
  • 52 Answers
Check the ribbon connectors for the lcds to there main driver board and reseat them. If that dosent fix your problem, than the driver board is bad. No easy fix to repair it. I have not seen the lcds them selfs be the reason for this, but it is also a slight chance.
Posted on Aug 26, 2008
My screen suddenly shows blue and pink vertical lines
Sounds like the gel has dribbled down into the workings and has effected the circuitry. Time for a new monitor. More importantly, why the heck were you using a liquid/gel sanitiser on electrical equipment. Use dedicated screen wipes
Sep 27, 2017 | Computers & Internet
I have 5 thin vertical white lines on the screen sound is fine.
It looks like the problem is comming from your LCD chips, they are starting to burn out and that is why you get this lines across your tv set, if you leave it like that the problem is only going to get worst
the lines will get bigger until it finally covers your whole screen you need to replace the OPTICAL BLOCK to fix this problem
good luck hopes this helps
please rate this solution !!!!!!!!!!!!!
Jul 05, 2010 | Hitachi FDX Series 43FDX10B 43" Rear...
Blue color on bottom screen and it is getting
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. You can find it here: http://www.discount-merchant.com/SONY-1-788-155-21-p/1179590.htm?Click=48173 Have a blessed one!
Apr 16, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blue tint across screen and black shadow of sort
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 02, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have more and more tiny bright blue dots
hello it may be the light engine that's faulty
shaun
Sep 19, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Rear projection screen 152cm lg going yellow
I am guessing that this is an LCD projection set, Please post the make and model so I can confirm. In the mean time, if it is an LCD, there are 2 possiblities.
1) The lamp may require changing. Sometimes the inner surface deteriorates because of the heat.
2) The "light engine" requires replacement as the heat and light have started to burn the LCD surface. This burning starts to show up as a yellowing usually onm one side first and spreading to the other side.
Dan
May 07, 2008 | Computers & Internet
Color spots on panasonic projection screen
The light engine may be dirty with dust, the polarizer filter burned, or the LCD elements burned.
As a last-ditch effort, the light engine can be taken apart and carefully cleaned using compressed air.
Apr 12, 2008 | Panasonic PT-50LC13 50" Rear Projection...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Screen now showing blue line at bottom
Sounds like, you have a bad optical block. Part can cost $550 to $800 + labor
Mar 28, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KDF-E42A10 42 in. LCD Television Logo
101 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
