Question about Creative Labs Nomad Jukebox Zen Xtra MP3 Player
My Jukebox will not take the charge
I just bought a new battery old one wouldn't take the charge , new one won't charge either.
When I plug the charger in the unit works, will not work without the charger being plugged in.
  • kjgiants Aug 26, 2008
    My Creative Nomad Jukebox Zen XTRA (40 GB) will not take a charge. I tried buying a new battery that dosen't work.....
    When I plug it in to charge it will turn on , but will not charge.
    that is not a solution !
  • Creative Labs Master
  • 6,487 Answers
There can be a problem with charging connector of the unit that probably is not loose and nees to be solder, that why you have ths problem, if you can take it to a service center and let them check the fix the problem that will be better because the unit may need to be dismantle and solder some parts on it or some parts to be replace..
Good luck........
Posted on Aug 26, 2008
    Master:
  • 763 Answers
Maybe you overcharge it and maybe the main problem is the device itself not the battery. if you can find anything to test those batteries and your device then try the two batteries from the shop that you bought it and see if it works.
CHARCOIS
  • 89 Answers
You might need to shock the device in order for it to charge again the battery.. in cellphones there is a device to shock the device, i just do not know if there is a device for your player.
    Genius:
  • 2,035 Answers
  • 435 Answers
Hi kjgiants,
Given below are some measures that you should try:
First, make sure the you are using the correct power adapter. Discharge your unit completely, by playing music till the unit will no longer turn on. Charge your unit for 8 hours, and test.
  • Narmada Anand
    Narmada Anand Aug 26, 2008
    Another reason could be:
    Unit does not detect the battery and is running on AC power only. You need
    to check and make sure that your battery polarity is correct making
    sure that positive goes to positive, and negative to negative.
  • Narmada Anand
    Thanks,.......
    Genius:
  • 3,422 Answers
If the battery isn't charging the problem is with the charger.
  • Priya darshan Aug 26, 2008
    As you said the unit works fine with only the charger plugged in then polish the terminals of the unit with
    a dry cloth and make sure the terminals are clean. If the terminals are
    covered with oil from your skin or similar matter, this may cause poor
    contact and battery power may not be fully supplied to the player
    Also,
    polish the battery charger terminals with a dry cloth before charging
    the battery. If the terminals are covered with oil from your skin or
    similar matter, this may cause poor contact and the battery may not be
    fully charged.
  • 13,433 Answers
IF you remove the battery does it function the same way? that would indicate that the battery is not connected into the circuit.. loose connection or broken wire.
  • Ekse Aug 26, 2008
    if you have another charger you could test that, incase the charger is wornout and doesn't provide enough power to charge the battery.
    also make sure the battery contacts are clean.
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
Feb 25, 2012 | Samsung SCH-U470 Juke Cellular Phone
Wouldn't turn engine over
check battery, for correct charge level,are you getting gas ,how about fire to the spark plugs?
I don't know about that year,(to new),but 1988,and some later models
have a module in the distributor that sometimes goes out ,and are heat sensitive if this is the problem you won't
get fire to the plugs untill you change it BEWARE!!!,
the last one i bought,i think was about $64.00
that has been a while so make sure before you run out and buy one!
I hope this helps
Dec 11, 2011 | 1995 GMC Safari
HTC battery wont charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 04, 2011 | HTC Desire Cell Phone
We have a compaq presario cq 60 bought in Canada and it's about 3 years old. Until yesterday, the computer battery would hold a charge for about 45 minutes (yes, we know we will have to replace the...
You need to replace your old battery. Don't over charged your battery. If you are using your laptop in your house it is better not to use it with battery. Just use the power adaptor/supply only. Then make sure you will drain the battery let say once a week. =)
Jul 13, 2011 | Compaq Presario CQ60-220US PC Laptop
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Jun 09, 2011 | 1997 Chevrolet Tahoe
Bought new AC adapter but connected it with wrong polarity
Hate to ask the obvious but have you replaced the batteries?
Jan 03, 2009 | Archos Jukebox Studio MP3 Player
My zen jukebox turns off then on and I just replaced and charged a new battery
Take out the battery. Plug it in. Does it play reliably?
Yes: That's a bad battery.
No: reset the device, and try above again.
Aug 14, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
New Battery Charge?
This means your unit does not see the battery and is running on AC power only. You need to check and make sure that your battery polarity is correct making sure that positive goes to positive, and negative to negative. If you can attach some photos, that might help also.
Aug 13, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
1,050 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
