Question about Maytag MGR5750 Gas Kitchen Range
Maytag MGR5750 Gas Range Oven Door Lock
The door of this oven wants to lock without notice, when it's not even being used, and no one is even in the kitchen. At this same time it makes a loud rattling sound and the "lock" light is on. If i unplug it, and plug it back in, it continues to rattle and wont unlock the door, even if i press "cancel".
Any ideas?
  • 639 Answers
Hi, I'm Neil
It is a fire hazard! Be Careful!
This time you will have to call the the manufacturer for service!
If it's under a year old ,your under warranty and it will not cost you anything!
Please give me a solution rating here!
Thank You
Neil
Posted on Aug 24, 2008
My oven door will not shut, i have a code of F9 showing
it MAY be your oven door lock is jammed..
I found this information for you:
  • Wait at least one hour after the oven has completed a self clean cycle to attempt to open the oven door, as the oven remains locked until the interior temperature has cooled sufficiently.
  • 2
    Press "Cancel" and wait a few minutes if the oven is cool and wait until at least one hour has elapsed since the completion of a self-clean cycle.
  • 3
    Open the oven door and check the door lock switch. Move the switch back and forth with your fingers to return the switch to the original position. Check for dirt or debris that may be causing the switch to stick or lock and clean as necessary.
  • 4
    Contact an authorized service technician if the problem is not resolved, as the door switch may need to be replaced.
  • Perhaps you can get some advice from Maytag
    Call the dealer from whom your appliance was purchased or call Maytag Appliances Sales Company, Maytag Customer Assistance at 1-800-688-9900
    Sep 12, 2011 | Maytag MGR5870 Gas Kitchen Range
    How to remove a Maytag gas stove oven door (Maytag Model # MGR5755Qwd)
    Hi.
    Before removing the door you need to release the lock on the oven door hinges. Door hinge locks are slide mechanisms or pins located on top of the hinges Once lock is released you will be able to pull out the door by opening it a bit, then lifting it up and pulling out.
    Here parts and diagrams for your oven: MGR5755QDW.
    Regards.
    Ginko
    Sep 09, 2011 | Maytag MGR5755QD CleanDesign Gas Kitchen...
    My Kenmore Elite gas range is beeping and flashing F90, the door is locked. What can I do to clear this?
    F90 Maximum oven door unlock time exceeded.
    F91 Maximum oven door unlock attempts exceeded.
    F92 Maximum oven door open time exceeded.
    F93 Maximum oven door lock time exceeded.
    F94 Maximum oven door lock attempts exceeded.
    1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
    2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
    3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
    4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
    5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
    6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
    7. If all situations above do not solve problem, replace EOC.
    F90 is a door lock code, Try this...
    unplug the range.
    wait 1 minute.
    turn the range back on,
    then while holding in on the oven door.
    start another self clean.
    wait 2 minutes.
    then cancel the self clean.
    do not release the door until the door lock light goes out.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^#$%
    Aug 28, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
    Hook up oven door on maytag gas range
    You likely need to lock the hinge in open position to do it. Either there is a small lever on the hinge itself you need to flip when the hinge is in the open position or there is a hole in the hinge, where you need to insert a steel pin (you can use screws, but they bend somewhat ;)) to hold the hinge open
    Mar 04, 2010 | Maytag MGR5875QDS Stainless Steel Dual...
    Lock light stays on, while one the oven will not start. Tried to disconnect power, but problem persists.
    Solved this specific problem (but seem to have encountered another). I stated a clean cycle on the oven. Once this completed then the "Lock" light correctly is now off.
    Nov 26, 2009 | Maytag MGR5750 Gas Kitchen Range
    Self-cleaning error message f90
    unplug the range.
    wait 1 minute.
    wait 2 minutes.
    Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
    What does the errror code F90 mean?
    unplug the range.
    wait 1 minute.
    wait 2 minutes.
    Nov 18, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
    Kenmore gas range trouble
    unplug the range.
    wait 1 minute.
    wait 2 minutes.
    Nov 20, 2007 | Kenmore 79383 Dual Fuel (Electric and Gas)...
    MGR5750ADW Gas Range locked
    Here is an excellent artical on that and should solve your problem.
    http://www.appliance411.com/faq/cleanlock.shtml
    Nov 18, 2007 | Maytag MGR5750 Gas Kitchen Range
    Maytag MGR5750 Gas Kitchen Range Logo
    116 people viewed this question
    Top Maytag Kitchen Ranges Experts
    vince
    gbob59
    Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
