Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whiripool when i ill it up with water it is leaking all over the floor before i do any wash
  • stxmassive_2 Sep 09, 2008
    9/9/2008
    water leaks out from underneath. i took a look and there was a white plastic housing device where two hoses are attached and a pump blade for pushing the water. I notice some heat bubbles where i suspect the leak is coming from. This is the second time i'm having this problem. I suspect that the design is cheap and faulty, due to the heat generated into the glue and plastic housing from the spinning blades. Is there another fix for this? I'd to have to replace this device only to experience the same thing months later.
    Thanks in advance,
    Rob Blackman
  • benham May 11, 2010
    is it overflowing the tub or is it leaking out of the bottom?
    Genius:
  • 1,027 Answers
The water level float switch needs replacing.
Posted on Aug 24, 2008
Injector assembly spitting water
IT is most likely misaligned.
Nov 24, 2013 | Maytag Washing Machines
Washer leaks water on floor
its possibly the door seal if its a front loader, or a hose, you can easily remove the back cover panel re attach any cords or hoses needed to remove the panel then operate it while looking for the source
Jun 07, 2013 | Washing Machines
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Wahing machine problem
bad lid switch,you can bypass it by putting the pos.neg wires together-mike
May 28, 2009 | Washing Machines
Water on floor when running, but hoses aren't leaking
never fear i to had this problem and by simply closing the door the water doesnt go on the floor. happy washing mr fixit.
Apr 26, 2009 | Washing Machines
Water leaking onto floor from under washing machine
first off check for punctures in hoses,
a leaking pump (common issue, youll see water dripping from pump area)
search you tube for whirpool washer repair, for simple instruction for removing hte outer cabinet
Jan 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Duet leaking
leaking water inlet valve very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
53 people viewed this question
Dan Webster
Dan Webster
Sal De
