Question about Canon PowerShot S2 IS Digital Camera
Error 50 I am getting the "E50" code. What can I do?
  • Canon Master
  • 4,738 Answers
Error 50 is an error in formatting the memory card. Try a different memory card (they're cheap these days). The current card may have died on you.
Posted on Dec 22, 2007
    Novelist:
  • 130 Answers
Do you have any more info? What happened before you got the error? Did the camera suffer an impact?
Posted on Mar 30, 2006
4 Suggested Answers
Fishi
  • 255 Answers
SOURCE: Error 50
The "E50" error code indicates formatting a SD card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem.
Posted on Aug 29, 2005
Fishi
  • 255 Answers
SOURCE: Error 50
The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem.
Posted on Aug 31, 2005
Fishi
  • 255 Answers
SOURCE: Error 50
The "E50" error code indicates formatting a storage card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another storage card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other storage card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the storage card for errors. Use ScanDisk to check the storage card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the storage card on the computer before you check the storage card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the storage card. Follow ScanDisk's on-screen instructions to solve the problem.
AEG Lavamat 60810 keeps stopping and displaying error E50 and some time E70. What is the problem and how do I fix it?
Family error code E50 means a problem with the washing motor. Family error code E70 means a problem with the NTC sensor. In my experience, E50 is most common fault in worn carbon brushes. But in any case family error code E50 is shown to the customer. In service mode could be: E51,52,53 and 54. The same applies to family E70 error code that will be displayed in service mode as error code E71 or E74.
E50 error code could be: motor winding, power board, tachymetric generator, motor relay on power board, wiring between motor and power board and wiring between tachymetric generator and electronic.
E70 error code could be: faulty NTC sensor, wrong position of NTC sensor or to much limescale on it and finaly wiring between NTC and electronic.
Dado
May 05, 2015 | AEG Washing Machines
Error code 50
Error Code E50. This printer error code flashes when the fuser unit of your Brother multifunction printer gets damaged. When this happens, it is a signal that you must replace your printer's fuser unit
Mar 15, 2011 | Brother Multi-Function Center MFC-240C...
What does the error-code E50 means in a crayola Kiddycam 25070?
hi,
The "E50" error code indicates formatting a storage card has failed.I think the e50 error code happens when the camera is reading and/or writing to the CF card when the battery are dead or real low. The camera does not get to finish writing data and leaves an error on the CF card. Use new battery or fully charged battery. I hope this may help you,
regards,
kaybicks
Feb 27, 2010 | Cameras
Error 50
Aug 31, 2005 | Canon PowerShot S20 Digital Camera
Error 50
Aug 31, 2005 | Canon PowerShot S1 IS Digital Camera
Error 50
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Error 50
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Error 50
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Error 50
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
Canon PowerShot S2 IS Digital Camera Logo
266 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
