Question about Jensen VM9510 Car DVD Player
Blowing fuses i have a dual xdvd700! i blew a fuse now when i put in a new fuse then reconnect the device it blows the fuse. Wat should i do?
  • 3 Answers
You need to check your wires and make sure that they are not touching anything that will cause this. The radio itself has a 10 fuse in it so there is a problem with your wiring. make sure that you are using electrical tape or some other adaquite protection. Also make sure that you are using the right type of fuse for your vehicle. If it call for 20 use the 20 fuse. many times people will change fuse rating looking for a quick fix. Hope this helps. If not feel free to email me at casey_eaglin@yahoo.com.
Posted on Sep 08, 2008
Why does the fuse keep blowing on my cub cadet ltx 1050
A fuse blows because the circuit it provide power to has a shorted component or wire.
May 16, 2017 | Cars & Trucks
88 toyota pick up v6 keeps blowing efi fuse
you may have a short of some kind, when a fuse blows repeatedly it is no good just replacing, you are being told that something is wrong with the equipment.
You will almost certainly have to visit a technician for a diagnosis. It is unlikely to be something that an inexperienced end user can sort out I am afraid.
GOOD LUCK
Oct 26, 2015 | 1988 Toyota Pickup
Why does the fuse in the plug keep blowing?
-The line go to the device touch ground or bad device.
-Check the device and line . If it's broken, replace it before replace
new fuse.
Good Luck
mai
Aug 05, 2015 | Cars & Trucks
Vr v8,engine fuse keeps blowing,what could be wrong? i have just replaced fuel pump
My friend had same problem so i waited till fuse blew an what i was doing when it blew the nutrel safety was getting hot replaced it now he is good to go
Oct 14, 2017 | Cars & Trucks
EMC1 fuse keeps blowing immediately in 02 chevy express 3500LS 5.7L engine
That fuse powers the pink wire that runs to the coil, injectors, and pcm.
If the short isn't obvious, I disconnect everything I can from the wire and then put in a fresh fuse. I turn the key on and check the fuse. If it blows, I know it's something I haven't disconnected or the wire itself. If it doesn't blow, I start reconnecting things one at a time untl the fuse blows again.
Oct 02, 2017 | Cars & Trucks
01 kia rio keeps blowing the injector fuse every time i put it in first and take off how do i fix it
You may have a shortted injector. Pull all the injector connections off, put a new fuse in. If it still blows the fuse, you must have a short in the injector drive circuit from the ignition switch to the injectors. I don't know what all is in the circuit, but you may have a resistor pack before the current reaches the injectors
If the fuse did not blow, then one at a time, reconnect the injectors. You are looking for a shorted injector that blows the fuse. If the first connection blew the fuse, disconnect that one, put in a new fuse, and start with a different injector connector. You may find one that blows the fuse, meaning it is shorted, and needs replacing.
Good luck.
Apr 08, 2012 | 2001 Kia Rio
Well i think i freid my amp i had a friend take a look at it and thats wat he said might of happened cuz as soon as i try to put a fuse in it blows it so idk wat to do now i want to get it fixed but in...
  • Open the Amp up. Look for any black spots on the board. If it "blew" you should see a burnt electrical component, perhaps a RCA jack where the cords go. That's the first step in looking at a suspected "blown amp"... is to try and see if you can see what blew.
  • Let me know what you find. If the fuse is blowing just as quick as the power feed is connected there is a burnt part of the board and/or a component. I suspect a diode. They allow current one way and are what one may say a fuse on the board itself in the form of a component.
  • Let me know.
Tony
May 30, 2011 | AudioBahn A2300HCT Car Audio Amplifier
Fuse #12 for 2000 lincoln towncar keeps blowing
fuses are a safety device. they are made to blower when to much load is drawn over them. some component on the circuit is shorting out. if possible unplug all the items on that circuit. put in a new fuse, then reconnect component one at a time until the fuse blows again. a process of elimantion. it may take some time, but it will be expensive to take it to a dealership.
Jan 10, 2009 | 2005 Lincoln Town Car
Blown Mains Fuse
You should repleace the old transformer with the new one
Jun 13, 2008 | NAD C370 2-Channel Amplifier
I just purchased and had installed an alpine pdx-1.1000 amp. powering 2 12" jbl's. while the owner was demonstrating this to me, we had it going loud, and it blew its 4 fuses. once he replaced the fuses,...
Technically, the manual says the amp should have 20A fuses, so by putting 25A fuses in, you've allowed more current to get to the amp before the fuses blow than recommended. I'd be more concerned about why the amp is blowing fuses.
If the subs are single 4 ohm voice coils and wired in parallel, you're fine. If they're dual 4 ohm voice coils, and everything (subs and voice coils) are in parallel, you're putting a 1 ohm load on the amp, which it's not rated for.
Mar 17, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Jensen VM9510 Car DVD Player Logo
157 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
