Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Get disconnected everytime the phone rings
I can't tell you what an issue this is cause my phone seems to always ring off the hook all day long. I get completely disconnected everytime the phone rings or I pick up the phone to make a call. This is totally confusing to me because I have CABLE internet and not DSL so it isn't even linked to my phone line.??? Other than that I'm loving my Belkin wireless G Router....can anyone tell me WHY this is happening and if their is a fix.
  • 1,027 Answers
Should not happen, unless you have the Modem card in the PC connected to the line.
Posted on Aug 24, 2008
I can make calls but phone doe not ring
You said "it seems to ring once then stops." One possible cause of what you're describing is called a "Ring Trip." It is characterized when the button that flashes to indicate an incoming call changes to steady red (which would normally indicate the call is answered) although no one actually answered the call. If that occurs, then you have to test to see whether you can tell where the problem is coming from. If you unplug all the phones, you can then call in (from a cell phone or other phone that's not part of the system) and see if the incoming call rings unanswered, as it should when no phones are attached. If all rings in OK, plug just one phone in at a time and call in to see if any particular phone causes the problem. If one causes the ring trip, then disconnect that broken phone. If ringing still stops when no phones are attached, you'll have to disconnect the phones' connection wires (Station Wires) at the phone system box that plug into the "Station Ports" (label them before you unplug any!). Do not unplug the plugs for the wires that feed phone company lines into the phone system, the jacks are called CO line ports. With the "Station" wires unplugged, see if If all rings in OK by calling in from a cell phone or other phone that's not part of the system. If all rings in OK, plug just one station wire in at a time to see if one causes the problem. If one station wire causes the ring trip, then disconnect that troublesome wire and inspect its "system box jack" and its phone jack for water damage, carpet cleaning solvent, exterminator spray or any other corrosive liquid damage. Sometimes a staple through a wire where there's humidity can cause the problem. This process will find the offending wire, jack or phone that causes a "Ring Trip." There are many other possibilities, but the extremely limited description you've provided "it seems to ring once then stops." doesn't help me send you a better answer yet.
Jun 27, 2014 | Panasonic KX-T7730 Corded Phone
I have a Uniden cordless unit hooked in 4 lines. Incoming calls ring briefly for about 1 second and go out! You can talk if you pick up but not sure why no normal rings. There is no problem calling out....
When someone calls you and your phone behaves this way, does the caller get disconnected? The phone may be causing this, but it may also be due to trouble in the telephone line itself. The trouble is caused by defective wiring, a partial short circuit. When you pick up your phone to call out, the voltage on the phone line is low and it works normally. When you get an incoming call, a high voltage is sent to ring the phone. Because of the partial short, the phone company's equipment thinks you've answered the call as soon as the ringing starts. But you haven't picked up the phone, so the phone company's equipment thinks you've hung up and disconnects the call. The result is that short burst of ringing.
Disconnect the cordless phone base unit from the line and try another phone. If you still have the trouble this confirms the line is at fault. You'll need to contact your phone service provider for service. If it's in the outside wiring, they're responsible for repair. If the problem is in your home wiring, you may need to pay them unless you have a wiring maintenance plan.
If the problem goes away when the cordless base is disconnected, then it's time for a new phone.
Jul 16, 2011 | Uniden Cordless Phone
The mobile does not ring when i get a call.the music also doesnot plays without sound.i used the mobile only for a month.i tried restoring factory settings but it doesnot work.can u please tell me...
Hi, what causes the phone not to be able to ring out is due to the ringer inside the phone that allows you to hear a ringing tone is bad.
You will need to replace the ringer inside the phone. When replaced phone will start ringing out and you can hear when it rings out.
have a nice day.
Aug 06, 2010 | Nokia E72 Smartphone
Ringing symbol on line b
When you are talking to someone, and you hang up the handset, does it actually disconnect the caller?
Apr 30, 2010 | Avaya 5400 Series 5410 Phone
MOTOROLA W376G...turn off phone on ringtone
Set phones ring style as "Vibrate then Ring" , "Vibrate" , or "Silent" to avoid the power on alert.
I set my ring style to "Vibrate then ring" so that I dont have to change the settings everytime I turn it on or forget to so when I receive phone calls or alerts it still rings & then I dont have to go back and change the settings again when I turn tha phone off so that is dosent have the power on alert.
This is the Only way I have found to turn the phone power on tone/alert off.
Change Ring Style:
-Go to Main Menu
-Select Ring style
-Then choose change, & set it to the ring style you want.
Feb 21, 2010 | Motorola Mobility W376 Cell Phone
When my phone rings the kids get booted off xbox live and i have wireless internet and wireless adapter for xbox360
Hi Jeannie,
Based on your problem I assume that you have DSL. When you get hooked up for DSL they send filters that you are supposed to put between EVERY phone and the jack. (Don't forget phone lines for satellite and alarm systems).
If your dsl drops every time the phone rings, there are usually 2 things that cause this.
1) A bad filter in your house. If a filter is bad or missing it can cause the dsl to drop either when the phone rings or if someone picks up the phone with the bad filter.
2) The other reason could be on your ISP's side. It's called a POTS splitter. You have one of these if you have BOTH phone and DSL. It's what sort of combines the 2 together. There are a number of problems that can occur with a bad pots splitter. i.e. DSL works - phone totally dead, Phone works-dsl - totally dead, disconnects, etc...
I suggest that you hook up the dsl modem by itself. DISCONNECT ALL PHONES IN THE HOUSE. Do NOT have anything connected at all except the dsl modem. No filters, phones, directv, digital cable, or anything else in a phone jack. Then when you are up and surfing, take your cell phone and call your house. Technically it should just ring and ring. Unless you have voice mail in which case it will go to voice mail after so many rings. Anyway, see if when the line is ringing in your cell phone if it is dropping you off. If it DOESN'T, then it's probably one of the filters, jacks, or wiring. If it still disconnects, it's probably the POTS splitter with your ISP.
Good luck and if this helped please help me out and leave feedback!
Feb 08, 2010 | Computers & Internet
My ringtone goes beep
  1. Push Menu
  2. Choose Settings (Wrench icon)
  3. Then Ring Styles
  4. Choose the second option (Ends in the word "Details")
  5. Change the ringer for messages to be different then calls
Aug 23, 2009 | Motorola Mobility RAZR V3
I loose internet everytime the phone rings
Absolutely. Wireless LAN is on 2.4GHZ. You will want to get a phone at a different frequency.
Apr 05, 2009 | Belkin Computers & Internet
Ring tones reverting to one I didnt choose
Could be the internal battery... that is bad i would take it to you service provider... see what they say
Oct 25, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Eliminate the "Inbox Full" and new text message notifications
well the answer to the first question is ya you can turn the annoying notifications off. All you have to do is go to menu-settings-audio-vibe & ring detail. then u scroll down to messaging and change it to silent.(your phone may not me vibe & ring detail its watever setting you have it on (ex. loud ,vibrate,vibe then ring) and this is followed by the word detail
Sep 24, 2007 | Motorola Mobility RAZR V3
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
167 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
