Question about Intel D850MV Motherboard
I can't boot with USB -
I have latest P15 bios
Option on bios USB boot is enable
USB key boots fine on new computers with with this motherboard, I have no luck.
  • jackbaurctu Aug 24, 2008
    Yes I set to boot from USB
    Boot sequence
    1.Removable device
    2 CDROM
    When I press "enter" on Removable Devices I see my Kingston USB.
  • xianwu2001 May 01, 2009
    can't boot from usb thumb.
    computer brand
    Acer Aspire T180
    PTS560X01265215E8D2702
    Main Board EM61SM/EM61PM
    BIOS 6.00PG
    BIO-ID R01-A4
  • 781 Answers
Have you set it to boot from USB otherwise it will boot from other first
Posted on Aug 24, 2008
  • David
    David Aug 24, 2008
    What programs do you have on USB that are bootable and if it comes up as a drive letter
    IE F:\type in dir /w this should bring up the contents in a list across the screen
    Then F:\ you type in whatever exe you have
    F:\ buspass.exe press enter the program should work if it is totally on USB
How to use a usb keyboard
as a P/S2 keyboard.plug it in the USB contact in the back.in any USB port.
Apr 08, 2013 | Dell Inspiron One 2305 Desktop Computer...
Won't read keyboard
usb or ps2 keyboard ? might need to be enabled in BIOS
If you want to use a USB keyboard to access Windows command prompt options, make changes in the BIOS (Basic Input/Output System), or to operate legacy operating systems, you must enable support for the device inside the BIOS.
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Turn on the computer and press the "Delete" key several times as soon as you see the initial boot or company logo screen. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Feb 15, 2013 | Dell OptiPlex GX110 PC Desktop
Keyboad failure on dell gx520 boot
Usb or Ps2 keyboard ?
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Enter bios restart your computer you will see a certain to press to enter set up usually the Delete or the F2 key this will vary depending on you computer and bios. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Enable PS2 & USB in BIOS You can enable PS2 and USB settings in BIOS by entering the BIOS setup screen when the computer boots. You will need to changes to the appropriate settings in this screen. The exact procedures vary by system, but there are a few common methods that may work if the motherboard manual is not available for guidance. The general procedure is the same for any modern computer system, but the menu arrangement and keystrokes to enter the setup program can vary greatly from one machine to the next. Power on or restart the computer and watch the initial boot screen to find the keystroke required to enter BIOS setup. This is often shown at the bottom of the screen. Typical keystrokes include pressing the "F1," "F2," "F9," "F10" or "Del" key. Press this key when the prompt appears on the screen. You can find the proper key in the computer's motherboard manual or on the website of the motherboard or computer manufacturer. Enter the BIOS setup screen and look for the "Advanced" or "Onboard Device Configuration" menu. Use the arrows to select your choice and press "Enter." Change the settings for the PS2 port by moving the menu choice to the "PS2" setting. Press "Enter" to bring up a smaller menu with the options to enable or disable the PS2 ports. Select "Enabled." You can also use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the PS2 port. Change the settings for the USB port by moving the menu choice to the "USB" setting. Press "Enter" to bring up a smaller menu with options to enable or disable the USB ports. Select "Enabled." Alternatively, use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the USB port. Save the settings and exit by pressing "F10" or using the "Esc" key to back out of the current menu. Choose to save and exit from the main menu if needed. Follow any additional instructions on the screen to save or navigate the menus. Hope this helps.
Dec 13, 2012 | Dell OptiPlex GX520 PC Desktop
Boot from a cd
Go to your BIOS settings and under boot devices, get the CD/DVD option ENABLED (This may vary slightly with motherboard models, but not too much). You may also change the Boot Priority (i.e, which device is to check first for the boot.ini file) but this is not a mandatory option though.
If you have CD/DVD booting enabled in your BIOS, the next time when you place a LIVE OS CD/DVD (bootable CD/DVD) in your CD/DVD drive and make your computer restarted, you will get a message during the pre-booting phase: "Press any key to boot from CD/DVD". You should now press any key to boot from CD/DVD.
NOTE: The new motherboard models all have CD/DVD booting enabled by default.
Hope this helps, Mrityunjay.
Jun 28, 2012 | Computers & Internet
The motehrboard bios doesnt boot from usb to install windows, how can i update the bios to boot from the usb?
Insert your USB jump drive into a USB port on the computer containing the bootable program. Copy the information to your jump drive, then insert the drive into a USB port on the computer you wish to boot the program from.
Power on the computer. When the computer begins displaying its startup information, hit the key indicated on screen to enter the computer's BIOS (the "F1" or "Delete" keys are commonly used to access the BIOS).
Browse through the menu options in the BIOS to locate the computer's startup and booting options to locate the "CMOS" menu, which is where you'll have the option to set which devices will boot at startup.
Browse though the list of bootable option---they'll be ordered as "First Boot Device," "Second Boot Device" and so on. Set the USB jump drive as the first bootable option---your BIOS may refer to the drive as a "USB Removable Floppy Disk."
Save and exit the BIOS. When your computer restarts, your program will boot first before your operating system.
Feb 17, 2011 | Intel QDI P2PE/800 Pro 82845PE Socket 478...
Setting bios to boot from a usb stick with an abit it7
If your motherboard supports it, it should be enabled by default. If it's not enabled and your motherboard does support it, then you can enable it by selecting the option from the BIOS menu. During boot up, press F2 to access the BIOS. Then, you should see an option that either says, "Boot from USB" or "Boot from External Device". Enable it by pressing enter and then selecting "Enable", If neither of these two options are available or something similar to it, then your motherboard does not support it.
Apr 22, 2010 | Abit IT7-MAX Motherboard
Doesn't recognize SATA hard drives. BIOS option
Need to install latest bios update go to there website also if you are trying to boot up with usb installed take it out. BIOS ID:15
  1. Fixed the issue where SATA HDD boot up will fail if USB storage device is installed.
  2. Fixed the issue where SATA HDD boot up will fail if "USB keyboard/mouse" setting as "BIOS" section.
  3. Enhance the compatibility of SATA device on WIN98SE/ME.
  4. BIOS compile date: 06/07/2004
Nov 28, 2009 | Abit KV7-V Motherboard
How can I boot from USB in a Thinkpad T22?
I assume with "boot menu" you mean the BIOS boot menu (the one you get to if you press F12 during start up, before the Windows screen appears.)
  1. Go to "Enter Setup"
  2. Go to "Config", click "Enter"
  3. Go down to "USB", click "Enter"
  4. Make sure that "USB Bios Support" is enabled.
  5. (Hit "Enter" again and choose between "enabled" and "disabled")
  6. Hit "Esc" twice to go back to the main page.
  7. Go down to "Startup", click "Enter"
  8. Choose "Boot"
  9. Check if "USB CD" is in the list of boot options or excluded form booting.
  10. Hit F10, confirm any changes you made (click "Enter" for 'yes') and reboot.
  11. Tap or hold down F12 again and you should see the boot option menu again.
Note: I am not 100% sure if you can boot from a DVD externally.
I booted from the internal DVD drive fine with a Linux LiveCD. It is possible that the T22 BIOS does not support external booting. Check you version - the latest release from IBM is version 16ET32WW (1.12), release date 06/03/2004. You find that info here.
I would really appreciate if you could come back here and leave a comment, so I (and maybe others?) can learn form this ;-)
Jan 30, 2009 | IBM ThinkPad T22 2647 Notebook
Booting Notebook using external devices.
This should do it for you.
On the Phoenix BIOS:
Go to "Advanced BIOS Features".
Go to the "1st Boot device" and set it to "USB-ZIP".
(Phoenix BIOS, Revision 6. you need to go to the Boot Order screen and select "Harddisk" and hit enter, giving you a list of IDE hard drives this BIOS prefers to call a USB device an IDE harddrive)
Jan 09, 2009 | Toshiba Satellite P15-S420 Notebook
Intel D850MV Motherboard Logo
1,062 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
