Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Maytag Neptune is Stuck on Settings and Will Not Start
We did have several power outages due to Tropical Storm Fay and I was washing.  Now the washing machine is stuck and will not start.  It was stuck on Hot Water and Regular Wash and would not let me change to Permanent Press and Cold Water and would not even start.  I unplugged it and all the lights blinked off and on but still no change.  I unplugged it again and now it is stuck on Gentle Cycle but still will not start.  My husband is pretty handy and has unclogged the drain on it a few times to make it work again just fine but this is a new problem.  Any ideas?
  • 639 Answers
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
This is an electronic problem. You did right to try and reboot the machine. It probably got a power surge during the storm!!
When there is an electrical storm it is not prudish to unplug or throw the circuit breaker on major electronically run appliances. ALL EXCEPT THE FRIDGE, of course!
I do this some times .
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
Displays on maytag neptune washer and dryer won't come on after a power outage
It may have burnt the main controls out on circuit boards or this sounds silly but check your breakers, did you have a power surge before the outage?
Aug 20, 2015 | Maytag Washing Machines
My Maytag Neptune dryer flashes an 88 when I push the start button, there is nothing in the manual about solution codes
lack of power did you recently have a brown out or power outage that may have messed up the breaker in the fuse box box
Aug 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My maytag washer mah5500b would not start after a power outage. it displays a code "do" and that's it. could you please tell me how to fix this?
power outage should not have caused this / but the do is (door) code it either didn't lock . or is unable to lock . the latch assem may have to be leplaced . try turning power of /just unplug and plug back in and try to program .. if it doesn't i would repl door latch .. pls feed back mm
Dec 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune washer stopped in mid cycle because of a power outage. Now it will not complete a full cycle. When I open the door, there is a pool of water in the tank. I have unplugged it, started it...
Try spin only cycle. Should drain water then spin. If that doesn't work it may be the power outage started as a power spike and fried your control board. Good luck.
Mar 01, 2018 | Maytag Neptune MAH5500B Front Load Washer
1999 Honda Odyssey A/C
I removed the harness connector and clean both sides with contact cleaner, leave some minutes to dry and connected again. after that it works fine again..
Thanks
Aug 22, 2008 | 1999 Honda Odyssey
Engine was flooded in tropical storm Fay, and will not start. Starter sounds as if it is trying to engage, but it is not. Can the engine be fixed, or is t seized?
you will need to drain all fluids and pull plugs out. if it was not running when flooded you should be able to save. remove plugs and disable fuel/ignition system spin over to blow out the water in cylinders
Aug 21, 2008 | Ford Crown Victoria Cars & Trucks
Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Jan 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
