Question about Ingenico eN-Touch 1000 Digital Pen
This problem is easily repaired. The heat seal connector between the PCB and glass is defective. For repair information contact
Posted on Nov 10, 2008
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
Sony DSC-S700 when turned on sometimes the screen is blurry and pink toned with blurry grey lines running accross the screen. Photos turn out the same. Happens intermittently. Have changed batteries,...
Hi there some how your camera LCD pressed by out side & the screen is damages. That's why you get the lines. Specially its come some particular area in the LCD screen. Just the way of resolve is resolve the LCD screen. Thanks & waiting for your feedback.
Apr 01, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Insignia 32" TV Thin line across screen 1-2" from top
This is usually caused by bad capacitors in the vertical circuit. If you have an electronics background you should be able to find the defective ones with an ESR tester .
Dec 16, 2008 | Insignia NS- 27" TV27 TV
Bottom touch screen blurry
it happens if there is moist or dust or sand inside the ds so breath INWARDS through the L or R buttons but dont pull too hard but **** as much as you can until it becomes alright plus keep doing it ... it took me 10 mins to get it right
Jan 05, 2008 | Nintendo DS Console
Red curved lines across screen
Dec 05, 2007 | Samsung HCM4215W 42" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
JVC AV-32F704 32" TV Picture is blurry - cannot read any writing on the screen
You didn't mention if you saw fine white diagonal lines running through the screen from top to bottom. If so, you likely have a shorted Picture Tube which is not usually fixable. If there are no lines seen running through the screen, then it is possible the High voltage transformer which also has a screen voltage and focus control built in that could be bad. I would expect the cost of that part to be about $100, so the repair cost total could approach that of a new set I would guess.
Apr 12, 2007 | JVC AV-32F704 32" TV
Blurring of images and text
mt, the 6 to 8 lines you were seeing were most likley the prelude to the end of the monitor. If the problem only occurs when the screen saver comes on then I could say the driver maybe being corrupted by a certain screensaver picture or program. When the monitor warms up to a certain temprature the electronics start to fail. You may want to turn off the monitor while your not right in front of it to cool it down and prolong its use.
Jan 27, 2007 | LaCie Electron 22" CRT Monitor
Ingenico eN-Touch 1000 Digital Pen Logo
265 people viewed this question
Top Ingenico Computers & Internet Experts
David Payne
David Payne
Are you an Ingenico Computer and Internet Expert? Answer questions, earn points and help others
