Question about BenQ FP731 - 17" LCD Monitor
BenQ FP 731 17" black LCD
I had turned my monitor off leaving my computer running while I slept. A friend tried to use my computer while I was in the shower, and I'm not sure what he did, but now the monitor won't display anything at all. He said he didn't know what button to push to turn it on, tried moving the mouse, thinking it was just on the black screen saver, but when that didn't work and he couldn't see anything, he thought the computer was off, so he pushed the button and shut down my system. When it started back up, I can hear it boot up, and the windows sounds come through the speakers, so I know things are starting as they should, but the green light just blinks on occasionally, and otherwise, there's no indication of life from it. Is it in some sort of standby mode? Did he change something I need to fix with a combination of pushing buttons? Is it shot? I've tried connecting it to my laptop and switching over to external video, and nothing happens, so it's the same with two separate PC's, my Dell Dimension 2350 and HP Pavilion laptop.
I hope I don't have to buy another one as I'm on disability and little money.
  • 1 more comment
  • Anonymous Dec 12, 2008
    same symptoms.
  • Anonymous Feb 21, 2009
    My monitor has the same symptoms as described. When I shut down my computer and turn the monitor off and then restart the monitor remains totally black. I finally unplugged the monitor from the computer and from the wall then reconnected and it came on immediately and works fine until I shut down again. Is it the monitor or the video card?
  • jbhmrh4744 May 11, 2010
    And just how do I do that? I don't have a clue what you're talking about.
  • 56 Answers
It sound like power on the monitor if it is this what you need to do.
Change the 2SC5707 transistors and electrolytic caps in the inverter
section. Also check the 3A picofuse, and resolder all transformer
pins. Are buy a new inverter board,this brand of moniyor is a Dell monitor.
Hope this help you.
Posted on Nov 11, 2008
Benq lcd fp0537s on for just 2 second
There are one or two capacitors in the power supply that open," leaving a slight puff at the top" in some cases.
Mar 16, 2012 | BenQ FP92W LCD Monitor
Trying to purchase a power adaptor for benq fp781 can only find one compatable for fp 791 would this work on a fp 781 monitor ??
On the screen itself, where it plugs in, it should give you a voltage rating, and a line with a C encompassing a circle. Make sure that these two things match up between the two screens, they should, but at the same time, there is the possibility that they don't. Also, make sure the plug is the right size. Yes, it should work, but I would just take the extra precautions listed above to prevent frying your monitor.
I hope this helps!
May 04, 2011 | BenQ FP781 17 in. Flat Panel LCD Monitor
I cant get correct resolution with windows 7 no apparent drivers of FP 222w under windows 7 (22 inch monitor)
You normally don't need any drivers for LCD monitors. The resolution should be 1440><900 or higher.
Samir
Feb 28, 2011 | BenQ FP222W LCD Monitor
When i plug the monitor into my computer the flashes Benq only!
Try connecting the monitor to a different computer, e.g., a laptop.
The power-cord to the monitor seems to be OK.
Check the "data" cable between the monitor and the computer -- try a different cable.
With the monitor turned on, restart your computer, and watch the monitor. The computer should show some start-up messages (white text over black background), followed by the Windows "splash" screen. If it does, the monitor is working correctly.
Jul 03, 2010 | BenQ FP737S-D 17" LCD Monitor
FP-768 (Silver, Black) (Black, Silver) 17 in. Flat Panel LCD Monitor: My screen goes haywire with all kinds of color cha...
The vertical lines/bar are sign of bad T-CON (LCD controller driver) board is bad, it is part of the LCD panel assembly, new screen will be needed, not worth it. You may try reseating the ribbon cable at the panel.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
May 16, 2010 | Fuji FP-768 17" Flat Panel LCD Monitor
Power light on no screen shown
unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
Nov 15, 2009 | BenQ FP737S-D 17" LCD Monitor
My BENQ monitor blacks out
Use the remote to access menu mode
then try inputs through the remote
Jun 16, 2009 | BenQ FP71G 17" LCD Monitor
Monitor Randomly Turns Black
I have exactly the same problem with my Benq FP71E+ ..
What i found is a temp fix is this :
When monitor dims and goes black i turn it off , hit the bottom left side (near the BENQ logo) turn it on again and it works ..
This works every time for me . But after a while it switches off again , could be 5 minutes could be 5 hours . Its random
May 02, 2008 | BenQ FP71E 17" LCD Monitor
BenQ FP7IB LCD monitor, turn black aftr BenQ logo
Try to plug into another computer and wait to see.
If it turn up to be same it somewhere defect from the main board of the lcd.
If if not the same turn up to be, you should reinstall the OS because the software is corrupted or your display card problem.
Apr 16, 2008 | MPC Computers AOC 7F 17" CRT Monitor
Fp91e
Problem with Inverter circuit.
Check with BenQ They offer a 3 year warranty.
Samir
Jan 19, 2008 | BenQ FP91ESIL (Black) (Silver, Black) 19"...
BenQ FP731 - 17" LCD Monitor Logo
326 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
