Samsung LCD Monitor Won't Stay On
My SyncMaster 171v suddenly turns off after an hour, sometimes two hours, sometimes 20 mins. I can't wake it up. The green power light turns off and the power button does not work. If I unplug it and plug it back in, it works for the next hour or two or 20 mins. All my hibernation settings, etc. are turned to "never."
A different monitor on the same computer worked fine. So I figured it's the monitor. But the bad monitor on a different computer worked fine.
Please help!
  • Anonymous Feb 07, 2009
    exactly the same monitor and exactly the same problem. Very frustrating
romsky79
  • 822 Answers
SOURCE: green light just flashes on and off and there is no displ
try to check your screen resolution maybe not compatible to your System. if green flashing there no signal from cpu to VGA cable monitor.
Posted on Jun 07, 2009
najah
  • 180 Answers
SOURCE: difficulty getting monitor to display when computer powers up
The Problem may be due to the defective inverter unit inside the monitor. Dry to resolder if any dry joint on the inverter PCB or replace the inverter board.
Posted on Jun 28, 2009
najah
  • 180 Answers
SOURCE: My computer monitor will not stay on.
The problem may with the Ram inside your computer
Posted on Jul 07, 2009
  • 1684 Answers
SOURCE: No display on SyncMaster 920NW after reboot from power failure
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. Look in our monitor repair section for step by step repair guide for this model it should be the same power supply as the 930. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 22, 2009
  • 286 Answers
SOURCE: My ViewsonicVP930b Monitor Suddenly Turns Off
This is a classic VP930 problem.
It is caused by bad capacitors in the power supply circuit.
Open the monitor, and look at the power board. There are six capacitors. Replace the 220uF @ 25V and the 1000uF @ 16V capacitors. I would recommend replacing them with 35V and 25V capacitors respectively.
If the serial number on your monitor starts with Q8H you could also have a bad IC on the main board. Q8 on the main board is an FET in an IC package. If this problem persists solder a wire from the right side to the left side. There is one pin that turns the IC on and off. All the other pins (per side) are soldered together. Do not solder the pin on the left side that is by itself. Just leave it. Solder ALL the other pins on the left to ALL the other pins on the right.
Remember, do this ONLY if the problem persists after replacing the capacitors AND if your serial number starts with Q8H.
Posted on Sep 15, 2009
Samsung SynchMaster 191N Monitor stay on fine for 15-20 min after that it goes dark,, and power swtich thrun itself off, cannot turn on or off, unless I unplug power for few min and replug. Then stays...
If the OSD has display and after a min goes dark that monitor has 2 possible problem. 1. bad electrolytic capacitor from secondary power supply to inverter area or fault semiconductors around inverter area. 2. Bad CCFL or fluorescent lamp of lcd panel it may be reddish color.
Sep 29, 2010 | Samsung SyncMaster 191T 19" Flat Panel LCD...
SyncMaster 216BW Monitor: it works for 1 hour suddenly the image goes and af...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Samsung monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 16, 2010 | Samsung SyncMaster 216BW Monitor
My Samsung Syncmaster 943BX will not wake up from sleep mode sometimes. Sometimes it comes right up, other times it may be 5,10,20 minutes before the display wakes up.
You probably have caps failing in the power supply.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Apr 29, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung 920nw display stay only one min and off but power on
This is due to backlite problem of LCD panel.
You may approach authorised service center for this issue they will solve your problem. Do not try to do yourself unless you have sufficient experience on LCDS.
Aug 05, 2009 | Samsung SyncMaster 920NW Monitor
Monitor goes black in 2 seconds
Check the data and power cables. One of them might be loose.
Apr 26, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
My samsung monitor syncmaster 743nx is not turning on..plss help me...tnx
How to troubleshoot a Samsung SyncMaster 743NX LCD Monitor? My Samsung SyncMaster 743NX monitor turns on slowly. I mean,last week when I started up my pc,it took 5-10 mins before my monitor displayed anything. I know the pc is already turned on because I've already heard the Windows Vista start up tune play. The problem is now getting worse as it now takes 20-30 mins before my monitor displays anything. Please help.
Mar 11, 2009 | Computers & Internet
SAMSUNG SYNCMASTER 191T PLUS
I have the same problem. Have you found a solution?
Aug 24, 2007 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Computers & Internet Logo
1,120 people viewed this question
David Payne
David Payne
