Question about HP Photosmart C3180 All-In-One InkJet Printer
HELP!!!! everytime i try to print something out, it tells me an error code 20 and i don't know how to fix it!!!!
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Gives me a code 5100
Canon i550 Service Error 5100 ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/25975
Oct 6, 2006 - I recently dropped my printer out of my car by accident, and now everytime I try to print something, it gives me a Service Error 5100.
Canon Pixma MX420 Printer 5100 Error and Loading Ink ...
? 5:57
https://www.youtube.com/watch?v=tmTJdJTAhYU
Mar 13, 2012 - Uploaded by Dustie Meads
please help me,i have problem in my printer,wifi on printer can't search .... I too was given the generic "5100" error message just tonight.
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
Why am I getting the error code 22550
It would be helpful to know the exact model number of your printer and the software level. If this is a PW300, it is an Initialization Error. Something is out of place that is not allowing the printer to start up properly. Opening and closing the lids may temporarily solve the issue but if it keeps on returning without having jams, there is either a sensor problem or the code level may need to get upgraded. New code levels have fixes that prevent false jam indications.
Jun 24, 2014 | OCE Check Plot Bond Paper, 20 lbs., 34" x...
Scanner error 20 in hp laser jet m1319f
HP Printer Error Code 20 is a very common error on HP printers, which will show when your printer does not have the correct settings / configuration to enable it to be used properly. The error will generally show when you try and print a document on your HP printer, and will claim that the "Printer Is Not Activated". Although there are multiple causes of this specific error, the good news is that it is very easy to fix if you know what to do.
The error you're seeing will typically show like this:
•"Printer not activated - Error code 20′
The reason for HP Printer Error 20 to show is mainly down to the way in which Windows is continually trying to use the printer, and does not have the right settings / options for it. Printing a document with an HP Printer Error 20 is actually quite a feat, and your PC needs to have your printer set up in just the right way in order to achieve that.
Fortunately, there's a very simple and effective way to repair the Printer Error 20 in the most effective way possible - by using the steps outlined in this article.
The way to fix Printer Error 20 is to first ensure that your HP Printer is set up to be the default printer on your PC. It's often the case that the printer you have on your system will either not be the default, or will have some sort of error that will prevent it from being properly used. To make sure this problem is not an issue, you should click onto "Printers & Faxes" on your system and then right click onto your HP Printer, and select "Set As Default". This will allow your PC to use the printer every time you print,removing some confusion.
After setting your HP Printer to be the default printing device for your system, you should then look to reinstall the printer on your PC to prevent Error 20.
You can do this by clicking onto "Device Manager" and then removing the printer from your system. On top of that, you should also look to remove any third party HP printer driver software from your PC, and install it again after a restart.
-Finally, you should also use a registry cleaner tool to fix the HP Printer Error 20. Registry cleaners are software tools which can fix any of the damaged settings and errors that your system might have inside. These tools are highly popular, and are used by 1,000's of people every day to help fix a variety of errors on your system. One of the biggest problems facing the HP Printer error 20 is the way in which many people's computers will actually have an incorrect file / setting inside the registry that's leading the error to show. To ensure this problem does not cause your system to become damaged, you should make sure that you can fix any registry errors Windows has.
Or the error may come like this :
Error code 20 Problem: "Not Enough Disk Space" error message
Possible Cause: Your computer needs free disk space to complete a print job. The amount of disk space required depends on the size of the file you're printing.
Solutions:
•A large print job has exceeded the memory capacity of the printer. Verify that the SIMMS or memory cards are seated. Add more memory or simplify the print job. Remember the original HP Laserjet has only 128K of memory available, the LJ+ has only 512K and neither one is really upgradable.
•On the 5P turn the image adapt and page protect to ON or AUTO. These can be set within the Remote Control Panel. Press GO to resume printing.
•On the 5L, set the Enhanced I/O to AUTO (PCL mode) and resend the print job
•Windows XP, click Start and then click Control Panel. Click Printers And Other Hardware and Printers And Faxes. In the Printers And Faxes window, from the File menu, click Server Properties, then click the Drivers tab. This shows the settings in your printer's driver. Compare the settings in this dialog box with the ideal settings in your printer's manual. If you see a discrepancy in these settings, the printer may simply need a new driver and delete old one. You can download printer drivers from the printer manufacturer's Web site.
• Get more help. Installing a new driver won't solve every printer woe, of course, so understanding printer's manual and Windows' built-in Help system will give you an even sharper troubleshooting edge.
Nov 09, 2010 | Office Equipment & Supplies
My printer will not print
Yuo need to downlode updated printer driver.
Feb 02, 2010 | Office Equipment & Supplies
I have C7180 All in one
Hi it could work I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 30, 2008 | HP Photosmart C5180 All-In-One InkJet...
My computer tell me that my printer as a error code 20
Error code 20 in HP printers usually means you are trying to print to a non-default printer. try setting your D7200 as the default printer. Here is the direct link to HP about your problem:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00759728&jumpid=reg_R1002_USEN
Jan 07, 2008 | Office Equipment & Supplies
HP Photosmart C3180 All-In-One InkJet Printer Logo
46 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
