Question about RCA D52W19 52" Rear Projection Television
Won't power on
When I turn on power button green lght ciomes on then powers off
  • 3 more comments
  • rodas72 Aug 26, 2008
    my tv made a noice like a fuse burne,in the back,but if i plug it again and turn it on, the green lite come on but it goes of f and no image
    .does this tvs,have fuses?
  • ouchimhurt Aug 28, 2008
    same problem- green on indicatior light flashes three times and doesnt power up.. and when it does turn on after hitting the on button for 2-5 times the picture has purple waves in it for a minute.
  • ryan_rasch Aug 28, 2008
    I am getting the exact same problem. Is there a solution to this or is there a part I can buy to fix?????
  • norman48 Aug 28, 2008
    I have the same problem, when I turn the tv on the green button blinks 2-3 times and stops. there is no picture or sound. I need help on how to fix the problem.
  • Anonymous Sep 01, 2008
    Same problem as these guys. TV "blinks off." Unplug for a while. Then plug back in and hit power button. Green light flashes a couple of times. TV makes a "staticky" noise. Then the green light flashes off. The kids think there is a "weird smell."
    Please advise.
    Thanks
My RCA D52W25 brought on Jun 2005 had the same problem 7 months ago: I turn it on and the green light blinked couples of times and then go off... not sound or picture at all. It also had a high pitching sound on the back because the flyback was arcing. I bought a new flyback and replace the old one, but again was arcing.
I talk to a technician and he told me to replace the Vertical IC (Vertical Deflection Booster P/N TDA8177F), That fix the problem with the pic and Sound, but the flyback was arcing and makin a popping sound. So, I took RTV silicone and sealed deep around the red power supply wire and that fixed the problem. Now after 7 motnhs, again I have the same problem with the pic and sound ( no problem with flyback). I will have to replace the IC TDA8177F again). Note: Use the IC with the F letter a the end, I used one without it and didn't work.... they are different.
Posted on Sep 09, 2008
  • welias1966 Sep 09, 2008
    The IC P/N TDA8177F is located right on from of the flyback, resting against an aluminum heat sink. It has 7 legs.
  • RCA Master
  • 5,138 Answers
Replace 2200uf 16v capacitor,and two 220uf 35volts they are located in front of chassis on power board Green and Gold colors noise sound or squealing sound is caused by coil LL037 also on same board.
Posted on Sep 04, 2008
My d52w19 chassis itc222 as posted most of the time wont turn on and the green light flashes three times every time it makes a small noise. sometimes it does turn on and you hear a little pop and the tv fires up.  latley there is a really high pitch noise that will slightly change pitch if you move the tv or put slight pressure on the top or botttom rear part of the chassis. thanks for the help as I have seen that this has been posted before without mention of the high pitch noise.
Posted on Aug 28, 2008
    left unplugged all day, plugged the TV in, hit the power button and it blinked three times and turned on. the picture just started to appear and I hit the power button on my cable box. there was a pop in the TV and it shut off????? whats going on?
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
Hp desktop blinking green light won't come on
mine does that when it's in stand-by mode. I just push the power button and it comes on....
Assuming you've already tried that....push and hold the power-button down for 5 seconds and the power SHOULD go out. *IF* it does not, then disconnect the power cord in the back for 1min....then reconnect and try to boot. If it *DOES*, then do the same...unplug the power cord for 1min and reconnect and boot.
Tallon41
Sep 14, 2012 | HP Computers & Internet
My Canon iP1300 won't print, message says Ink Absorber is full and I am not too sure what do do?
Hi, please try doing this:
1. Turn off printer.
2. Retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
6. turn off printer by button POWER.
It is undertaken from service manual. I hope this helps.
Aug 20, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
No power
It sounds like the backlight or an inverter board on the television may have failed. Check your warranty status on the television to see if you can get it repaired by the manufacturer for free.
Sep 06, 2007 | Sony KDL-32S3000 32 in. LCD Television
RCA D52W19 52" Rear Projection Television Logo
381 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
