Question about Audiovox VM9512 Car DVD Player
Dvd player for my car
I am try to bypass my blue screen on vm9512 so i watch my dvd all the time
  • algu35alex Sep 15, 2008
    me pide una llave
    Problem Solver:
  • 5 Answers
  • 1,586 Answers
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 24, 2008
2 Suggested Answers
SOURCE: dvd player for my car
Could someone tell me how to connect automatic antenna wire for car and it raise up when turn the radio or turn the stereo on ?
i had connect the blue wire to antenna put is not working?
Best regards
David
Posted on Aug 25, 2008
I have a dvd/cd stereo and it is asking me to install the emergency wire which is the pink wire that turns out to be a ground where do i hook up inorder to watch the video while car is in motion
you need to install a toggle switch run one terminal to a ground wire or any metal grounded to the car and hook the pink wire to the other terminal. flick the switch off and on a couple of times to bypass the warning screen.
Mar 18, 2010 | Audiovox VM9512 Car DVD Player
DUAL XDVD9101
the 9101 is built so you cant bypass
May 08, 2009 | Audiovox VM9512 Car DVD Player
Need help with brake bypass
you have to connect the wire that supose to go in the brake switch on the grounded side of that switch, now what color the wire is? it depends what brand and model of stereo you have
Apr 15, 2009 | Audiovox VM9512 Car DVD Player
Best regards
David
Aug 23, 2008 | Car Audio & Video
VM9512 no audio
Run your blue wire on your harness plug the blue and white of the head unit. The blue wire on the deck is for your radio antena and turns off when you switch to cd. This should fix your problem.
Jun 28, 2008 | Audiovox VM9512 Car DVD Player
Parking Brake Bypass
Hi
You need the remote to do the code thing, or try hooking the parkbrake sensor up to full time power to trick the unit into thinking that the parkbrake is off. Try that and see how you go. If it doesnt work that way, try taking it to full time chassis(earth)
regards
robotek
May 15, 2008 | Audiovox VM9512 Car DVD Player
Hello there
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
Mar 18, 2008 | Audiovox VM9512 Car DVD Player
JENSON VM9512 CODES FOR BRAKE BYPASS
Mar 10, 2008 | Audiovox VM9512 Car DVD Player
Jensen VM9512 in-dash DVD player
with the remote:
press set up button
scroll to highlight language
enter 5,4,3,2,1,0
you will now be in a secret menu
turn on brake bypass
and exit
done
Dec 14, 2007 | Audiovox VM9512 Car DVD Player
Audiovox VM9512 Car DVD Player Logo
94 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
