Question about Panasonic RX-FS470 Cassette Boombox
The auto stop mechanism seems to have completely stopped working. When play a cassette, it eats it. When you put the deck into play mode without a cassette and push on the pinch roller with your finger, it does not stop as expected. The auto reverse switch also does not seem to function (I have not tried it with a cassette in for obvious reasons).
  • evokat3ur Sep 04, 2011
    FF and REW actually do work, yet, during playback, the take up reel does not turn, I did clean the head, capstans, etc.
    Brigadier General:
  • 8,546 Answers
When's the last time it was cleaned? It surely needs it now.
Never touch the any part of the transport that directly contacts the tape with bear fingers.
This sounds like a failure of the take-up (left) reel to take up slack as it's fed in by the capstan.
You can probably trust the machine to fast forward or rewind a tape to test the ability of the reels to manage slack since either action only requires one reel to pull while the other just coasts. Failure would look like stationary tape that eventually would time out and reset the command.
If it won't do fast transport motions that eliminates the capstan/pinch roller.
If it CAN FF and REW then the capstan, pinch roller, heads or something is probably glommed up with sticky tape oxide, which brings us back to the first question.
Posted on Jun 30, 2011
  • David Dunn
    David Dunn Sep 04, 2011
    If FF and REW work the reels have enough torque. Failure of the capstan pinch wheel will result in no apparent tape motion other than the reels will tension the tape slightly as they oppose each other. Experiment with an eaten tape if you don't trust the machine. Just FF opr REW to a smooth part.
SOURCE:
Denon udra-77 hi the cassete deck will not eject or close on pressing the open close button, the rubber band between the wheel is intact, it will activate when manually turning the top wheel, seems to be...
The mechanism maybe out of alignment. Technicians and a service manual is how this gets fixed. The new belts are put in an the mechanism is position to the stop mode for the eject to work.
Feb 09, 2014 | Denon DRR-M30 Dual Cassette Deck
Pioneer CT-W208r won't eject tape.
These dual cassette decks were throw away units in most cases. The belt inside and the grease in the cam mechanism is in bad shape and the deck can not cycle through the steps it need to so as to reach stop. Only stop mode will allow the door block to release. The tape can safely be extracted by a Technician. The deck need work. Dual cassette decks are not always worn the repair cost.
Dec 23, 2013 | Pioneer CT-W208R Single Cassette Deck
Panasonic SC-AK45 stereo not playing cassette tapes
I may not have worked on one of these before but all tape decks have some common drive parts. Yours is missing the proper torque to drive the reel table in take-up for play and your fast wind observation also points to either drive transfer problems or the motor itself. I suspect the fastest answer is to have a tape deck technician work on it. Dual cassette decks are not known for being the long lasting products like a singles cassette deck is.
Feb 23, 2013 | Audio Players & Recorders
How can I eject a cassette from deck A it has taken the cassette and is not ejecting it nor is it playing it
The loading is not completing and so the mechanism will not release the forward eject of the cassettte to work. So please check on the belt and if this is worn then the loading will not work as it will slip and so will not complete the loading back to rest mode.
Jul 22, 2011 | Technics RS-TR575 Single Dual Cassette...
Vcr will not play tapes,it ejects the tape after a few seconds
This may be caused by the mode switch.
By the way it uses a K-Deck Mechanism.
Sep 11, 2009 | Televison & Video
Yamaha K-720 cassette deck will not play tape--immediately stops on auto-stop (or, perhaps, auto-reverse.) Fast-foward and fast-rewind are okay. Had this same problem repaired in the 1980s. How do I...
your problem is the flat belt that drives the 2 capstans. I asked you to check switches but remembered afterwards there is a different motor for fast forward reverse. When the machine is powered on, the capstan motor runs all the time. I bet the 2 capstans are not turning. You can see this if you slide up (gently) the cassette tinted cover. You need a new belt. If you are handy, you can do it yourself (about 2 hours) but it is tricky as you have to remove the complete cassette mechanism and then partially dismantle it to put on the new belt. If you need help I can probably guide you a bit. I just did it a few months ago. The belt size is 9.6 inches. One part number is FBM9.6 or you can try Yamaha service.
Jul 04, 2009 | Audio Players & Recorders
Denon Dual Cassette Deck DRW-660 will not eject either tape. I put a tape in right side, played a bit, stopped, will not eject. I put another tape in left side, closed, cannot eject. Cannot eject either....
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
Apr 05, 2008 | Audio Players & Recorders
Kenwood KX-W6080 dual stereo cassette tape deck
I have the same unit which had the same problem. It has to do with dirty contacts on each tape mechanism.
Remove the main cover and look down on each tape mechanism. You will see 4 contacts on each unit. These come in contact with the tape. Remove each unit by removing 4 holding screws.
You will now be able to spray some contact cleaner into the front of the plastic contact cover. I removed the covers on both of the second from the right contacts so that I could clean them with an abrasive. These are the main ones.
Put everything back the way it was and the tape deck should work great.
Mar 24, 2008 | Kenwood Audio Players & Recorders
Left Deck Door Stuck Shut on Cassette Deck
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Feb 04, 2008 | Audio Players & Recorders
Panasonic RX-FS470 Cassette Boombox Logo
473 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
