Question about Jensen VM9511TS AM/FM/CD/DVD/SD Player/7" LCD Car Video Player
How do i bypass the parking brake switch in order for my video to play
Isn't there a way to bypass the parking brake so my video plays anytime i want parking brake switch
I bypass the parking brake but now it's not reading the dvd how can i fix it
Posted on Sep 14, 2008
  • 1,586 Answers
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 24, 2008
I think the wire that should go to your hand brake is green, all you need to do to bypass this is hook it to an earth.
May 06, 2009 | Clarion MAX385VD Car DVD Player
Take the wire that they tell you to hook to your parking brake and hook it to ground instead.
Feb 27, 2009 | Pioneer Car Audio & Video
ITS just a ground cable hook it to the radio ground i did and mine works fine
Aug 21, 2008 | Jensen's VM9312 Car DVD Player
get the lockpick. gen5. about $249. just google for your vehicle
Jul 12, 2008 | 2008 Chevrolet Avalanche
To bypass the parking brake you should connect the parking brake wire from the unit to ground. It is better to do it via a switch because is illegal to watch video while you're driving. :)
May 15, 2008 | Car Audio & Video
Ground the handbrake wire to the outerpart of the "line out" connector if it's not in use, works a treat
Apr 29, 2008 | JVC KD-AVX11 Car DVD Player
N1 internal solder bypass to work with newer software, N2 solder the two connection under the silver sticker(might void warranty), N3 switch the switch under the silver sticker(might void warranty). Goodluck.
Mar 31, 2008 | Pioneer AVIC-N2 Car DVD Player
get a toggle switch hook to a ground then to the e-brake wire flip on and off 3 times 4th time leave on worked for me
Mar 19, 2008 | Dual XDVD8265 Car Video Player
you need 2 toggle switches . yello/blue wire to switch - switch to ground.
yellow/black wire to switch- switch to red ing. wire. turn this switch on and pulse the other(yellow,blue) 3 times and leave on, then turn the other switch off and then you can ride and watch dvd. just did it this morn. QTRHRS
Feb 24, 2008 | Alpine IVA-D310 Car DVD Player
Car Audio & Video Logo
447 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
