Updating BIOS I upgraded my computers RAM memory and was told I had to update my BIOS to make it work. How do I update BIOS? I am totally clueless. Thanks! Hi, I just changed the ram in my acer aspire 5630 from 2GB (pre-installed) to 4GB (supposed Max.) but the System still shows only the 2GB. I re-booted twice but it will not show up. What else do I have to do?
  • Conny Aug 24, 2008
    Thanks, but the link doesn't work for me.(error 404)
    I was told at kingston's help desk that the cards have to be re-inserted uo to 10 times to make it stick and tick.
    It's to late to try this today, but I'll do it tomorrow.
    Any other ideas?
    Sergeant:
    Novelist:
  • 166 Answers
You need to upgrade your bios.
Heres the link the software.
ftp://ftp.work.acer-euro.com/notebook/aspire_5630/bios/Bios%203.23.zip
You will need winzip or winrar to open the zip file just google either if you dont have them you can get them for free.
You then need to open the folder you just uncompressed and you will see another zip file, winflash is in there. it will allow you to flash the bios from within windows, just install it and follow the instructions on your screen
Dont forget to rate this solution
Posted on Aug 24, 2008
Asus f3j bios mod for upgraded ram
Not sure what you are asking about. Asus site says the motherboard will take DDR2 533/667MHz SDRAM, 2x SO-DIMM socket expandable to 2GB
Which means DDR2 533mhz 1 gig per slot total 2gig
or DDR2 667mhz 1 gig per slot total 2 gig
To enter BIOs press F2 at boot up, but no setting should need to be changed.
They do not have a BIOs update for increasing the memory limits.
BIOs upgrades from first to current are.
BIOS 304
Update new CPU Microcode
System plays wave file and causes garbage sound.
BIOS 305
To fix system cannot do battery pre-charge process when an unknown/failure battery insert.
Support Intel Extend ID CPU:Merom Celeron 530 CPU.
BIOS 306
BIOS 307
Fix System hang at ASUS LOGO on SATA HDD with factory recovery image
Last upgrade date is 2008 7 14
Mar 14, 2014 | ASUS F3Jc Notebook
How do I upgrade my bios for toshiba laptop ?
Why do you want to update the BIOS of your laptop? Be careful about updating your BIOS because it might cause your computer to crash.
Or are you trying to update the drivers in your computer?
If you are having some issues with its performance, then you need to update all the outdated drivers in your computer. I know that it's a total headache if you do the update manually but don't worry because there are Automatic PC Updater like RadarSync. It will scan and update all outdated drivers in your computer.
I hope this helps!
David
Feb 07, 2013 | Toshiba Satellite A205-S5879 Laptop
Dnt have enough ram to install internet. how do i update my bios so new ram will work on emachines 400i3.
I did a little research on this model, and sadly it may be time to put it to pasture. It uses Win 98 with a 4GB drive. This tells me it just can't handle today's media rich internet. Let alone finding a BIOS upgrade.
GL
Jan 09, 2013 | FSP Emachine eTower 400i3 Power Supply...
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
Need BIOS update for my MX6424 Gateway with Win XP
If your board is not supporting the 2gb memory module, it won't make any difference by upgrading the BIOS.
Aug 27, 2009 | Gateway MX6424 Notebook
Adding ram do I need BIOS update see detailed question
I don't think that this will work! I think 512 is the maximum for it. May be it'll just improve speed a little but it's always risky to update BIOS on older PCs. And this 512 sticks will cost you a lot. I think you better think to buy a new PC. Good Luck!
Apr 17, 2009 | Compaq Presario 7588 PC Desktop
Will not recognize Ram
Insert a pair of memory so you again can see a total memory of 1024GB. Check the slots you have them inserted in. It should be DIMM A-1 & B-1. (Correct)? Remove both & insert the second pair. Use A-1 & B-1 again. Check total memory reported by bios. If you see anything less than 1024GB, that set of memory has an issue. Continue to leave in that set of memory. Go to this link & download memtest86 to a floppy disk & test the memory. You'll find the download section just under the three screen shots.
http://www.memtest.org/
Each set of dimm's should be placed like so. One matched pair in dimm A-1 & B-1. Second set insert into dimm A-2 & B-2. The bios should see the total as 2GB. Run memtest only while using one set of matched 2x512 memory at a time. If there is a problem with the memory memtest86 will find it.
Though the information should fix you're issue, (or catch some bad memory).
It wouldn't hurt to check if a bios upgrade will help also.
Click on this link & check you're bios version against Asus updates. Please only update if you are sure the update will help.
http://support.asus.com/download/download.aspx?modelname=A8N-SLI%20Premium&SLanguage=en-us
Good Luck!
Mike
Jun 17, 2008 | ASUS A8N-SLI Premium Motherboard
Updating BIOS
Dear Sir/Mam
This is the Paddy_solver and since you are not able to find the bios upgrade i am giving you a link from where you can download your bios update however before you would do it lemme tell you it can crash your motherboard as well i would say if your computer is working fine you better not do it if your computer administrator has said so please go for it.
Link to download :-
http://support.acer-euro.com/drivers/utilities.html#BIOS
when the website would open you have to look in the middle of the page where it says "BIOS UPDATE TOOLS"
NOW BEFORE YOU WOULD INSTALL OR DOWNLOAD ANYTHING PLEASE MAKE SURE YOU SHOULD KNOW THE BIOS INSTALLED ON YOUR LAPTOP FOR THAT YOU HAVE TO ENTER THE BIOS EITHER BY PRESSING "DELETE KEY" OR "F2 KEY " ONCE YOU RESTART THE LAPTOP TRY IT BOTH THE KEYS ONE BY ONE IF YOU ARE NOT ABLE TO GET TO THE BIOS.
AND ONCE YOU WOULD SEE THE BIOS IT WOULD EITHER SAY "AWARD BIOS" OR "PHOENIX BIOS" ONCE YOU KNOW WHICH BIOS YOU HAVE THEN DOWNLOAD THE FILE ACCORDINGLY.
HOPE THIS INFORMATION IS USEFUL FOR YOU IF ANY FURTHER QUREY YOU CAN CONTACT ME AT MY EMAIL IE:-
sumitfor_u@yahoo.com
Thanks and Regads
Paddy_solver
Nov 29, 2007 | Acer Aspire 5100 Notebook
My Dell C610 won't reconize the second stick of 256 mb memory
As the computer boots, it detects the additional memory and automatically updates the system configuration information
where did you get the memory?
If it is in properly and does't work,it is either bad or the wrong part number for your Dell C610
Nov 27, 2007 | Dell Latitude C610 Notebook
Computers & Internet Logo
435 people viewed this question
David Payne
David Payne
