Dell Dimension 2400 PC Desktop Logo
Posted on Jun 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
In the command prompt,what does an IP configuration do?
Anonymous
Level 2:
Sniper:
  • Expert 64 Answers
  • Posted on Jun 30, 2011
Anonymous
Expert
Level 2:
Sniper:
Answers
64
Questions
Helped
16584
Points
258
It is depends on what you do with it. RENEW-renews your ip adress ALL-gives you your ip info RELEASE-releases your ip
Testimonial: "cool"
Anonymous
Level 3:
  • Dell Master 32,281 Answers
Anonymous
Dell Master
Level 3:
Answers
32281
Questions
Helped
7907963
Points
102259
When you enter ipconfig in the DOS box it displays the current IP configuration of the LAN and or wireless cards.
This information is useful when you have a network problem, it displays the IP address, sub net mask and gareway.
4helpful
Can you tell me the default IP address for this unit as I have lost the pass word and need to reset the unit
If your computer is plugged into the router, you can easily get the router's IP address by going to your command prompt and typing "ipconfig" without the quotes.
Command Prompt is under Start (or Orb if using Win7 or Vista) > All Programs > Accessories
After typing "Ipconfig" and hitting return, command prompt should display something like this:
Windows IP Configuration
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . : blah.blah.comcast.net.
IP Address. . . . . . . . . . . . : 192.168.0.196
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Ethernet adapter PdaNet Broadband Connection:
The router's address is your "Default Gateway." You should be able to put that address into an Internet Explorer window and it will bring up the configuration interface.
If you find this helpful, please rate me -- trying to get my "Wiz" rating so that I can provide Premium service.
Thanks,
Chris
tip
How to find your Router's IP address
The easiest way to know your Routers Internal IP address is by using a little command line tool called ipconfig. This command line is built in with Windows Operating System and is being used for various networking solutions. To use this, you need to click Start and find the run command. Click the Run command and you should see a little run dialog box after.
In the run dialog box, type in cmd and either press ENTER or click the Ok button. You should see a black window with white text and this is referred to as the command prompt.
At the command prompt type in ipconfig and press enter. That should display three major information. The IP Address, Subnet Mask and Default Gateway. The IP address in line with Default Gateway is your router's Internal IP address.
Each Router has Internal and External IP address. The internal IP address is what you use to talk to your router. Use this IP address to login to your router setup page and configure it for things like port forwarding. External IP address is what the rest of the world uses to find you on the Internet.
Hope this helps.
on Apr 20, 2011 • Computers & Internet
3answers
What is the ip address of my dell dimention 2400
To find out your IP address you need to access the command prompt. To do that, click on the start button, click on accessories and then click on command prompt. Then type in ipconfig and hit enter. That will give you your ip address.
Thanks for using FixYa!
1helpful
2answers
Intermittently, my home network and internet access ceases to function. Troubleshooting indicates the "Local Area Connection" doesn't have a valid IP connection. Resetting the router (12...
Going inot the router configuration page and reserving your computer with a specific IP address would resolve this issue, If you have never gone into the router config page, it would be reccomended that you not do this, and have a computer savvy person with networking experiance do this for you.
another solution would be releasing and renewing your IP address in the command prompt on your computer
in command prompt, type : ipconfig /release ENTER then ipconfig /renew to renew your ip address, this can be done rather than resetting the router everytime
I want to reconfigure this so xbox will work on second computer the second computer works but it will not automatically pick up xbox, I have disabled wireless and hit the reset button when I type in...
Hi.
To configure the router you must connect to the router using a cable.
Ensure that IP is 192.168.1.1 , and not 192.168.0.1 for example.
If you are using a computer to configure the router, turn off the firewall.
You can find out router IP opening the command prompt (type CMD in run box) and typing ipconfig/all in the Dos command prompt.
Router IP will be indicated as default gateway.
Regards.
1helpful
How change ip address of epson epl n2500
Hi, i know its been months already but i have a solution to your problem, we have same problem and i solved it already..First, you have to get the ip address of your printer,..Then, open command prompt..
At command prompt, Try this command;
telnet ip address (this is your ip address)
Then, as you can see, their is a lot of instructions there..
So, you must follow it..
Take note: It automatically saved the changes.
Second options:
Type the ip address of your printer at web browser, it looks like this:
http:/192.168.1.100/ (this must be your ip address)
Then, as you can see, there is a lot of choices there.
So, you have to choose the configuration to change your old ip address.
I hope it can help you..
Thanks
Windows can not configure router, router does not show in network connections
could you please put more detailed information please?
Try the following.
-Open Command Prompt (Start > Execute.. or keystroke "Windows Key+R"
-Enter "cmd" (without quotations) and execute
-Enter "ipconfig" in command prompt
The Default Gateway is your router.
Try accessin http://<I.P. Router>:8080
If you can't access your router try pinging the device by starting command prompt and execute he following command:
"ping <I.P. Router>" (without quotes)
(replace <I.P. Router> with the actual I.P. address of your router)
2answers
How can i configure the Ip address and dns in dos mode
netsh [-a AliasFile] [-c Context] [-r RemoteMachine] [Command | -f ScriptFile]
? Displays a list of commands. add Adds a configuration entry to a list of entries.
add helper Installs a helper DLL. delete Deletes a configuration entry from a list of entries.
delete helper Deletes a helper DLL. dump Displays a configuration script. exec Runs a script file. help Displays a list of commands. interface Changes to the `interface' context.
ip Changes the 'interface ip' context. ras Changes to the `ras' context.
aaaa Changes to the `ras aaaa' context. appletalk Changes to the `ras appletalk' context. ip Changes the 'ras ip' context. ipx Changes to the `ras ipx' context. netbeui Changes to the `ras netbeui' context. routing Changes to the `routing' context.
ip Change to the 'routing ip' context. ipx Changes to the `routing ipx' context. set Updates configuration settings.
machine Sets the current machine on which to operate. show Displays information.
show alias Lists all defined aliases. show helper Lists all the top-level helpers.
Available commands after you have entered the netsh command (typing netsh at the prompt and pressing enter).
.. Goes up one context level. ? Displays a list of commands. abort Discards changes made while in offline mode. add Adds a configuration entry to a list of entries. alias Adds an alias. bye Exits the program. commit Commits changes made while in offline mode. delete Deletes a configuration entry from a list of entries. dump Displays a configuration script. exec Runs a script file. exit Exits the program. help Displays a list of commands. interface Changes to the `interface' context. offline Sets the current mode to offline. online Sets the current mode to online. popd Pops a context from the stack. pushd Pushes current context on stack. quit Exits the program. ras Changes to the `ras' context. routing Changes to the `routing' context. set Updates configuration settings. show Displays information. unalias Deletes an alias. Examples
netsh Enter the netsh command. netsh dump Dump all the network information as a script to the screen. Can also be sent to a file by doing netsh dump > file.txt . This script can then be executed using the exec command. set address name="Local Area Connection" source=dhcp Set the "Local Area Connection" to DHCP. set address local static 10.0.0.9 255.0.0.0 10.0.0.1 1 Set the local address to Static. netsh interface ip show config View network ip configuration. Below is an example of what may be seen. Configuration for interface "Local Area Connection"
DHCP enabled: Yes
InterfaceMetric: 1
DNS servers configured through DHCP
WINS servers configured through DHCP
1helpful
How to configure router
In order to find out the ip address of your router...
click start>all programs>accessories>command prompt>
in command prompt put in ipconfig and press enter it will give you the option of default gateway that is the ip address for your router.
Driver help...Anyone?????
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the 192.168.1.1 OR 192.168.0.1
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
