Question about Roper Washing Machines
I have own my washing machine for 13 months , and it dos not work any longer , it's leaking oil . What should I do?
If it is fairly new ,you fix the oil seal in the gear box
If it is 15 years old ,get a new machine
Posted on Jun 30, 2011
SOURCE:
Hi we have literally just brought a Hoover dyn 7164 d and on first check-which the manual asks us to the error code e03 appears and will not drain!!!what do we do??its full of water!how can something...
What a heap of junk of a machine. The one I own died after 13 months taking the electrics in the house out with it. A faulty heating element was the cause. They leak over their electrics with predictable results. A modified element has been fitted. Avoid this and all Hoover products like the plague.
Dec 02, 2012 | Washing Machines
Hi, I have the WA13V5 toploader. The machine is 7 months old. Yesterday the machine still worked 100%. This morning the water does not want to flow into the machine. I have checked the water flow and the...
Hi
There is a filter located in the pipe between the connector to the water outlet and the machine, This sometimes gets clogged. If this dos not solve the issue then time to call a tech. Anyway your machine is just 7 months old and it should still be in the warranty period and the service should be free.
Regards.
PLZ. don't forget to rate my suggestion.
Jul 19, 2011 | Samsung Washing Machines
Our 3 month old machine started making a high pitched squeel the other day during the wash cycle. Now it has started on the rinse cycle on the Quick setting. Model LD149.
I share your frustration with the same machine. Mine is approx 3-4 months old and within the first month i had a leak at the base of the machine which was fixed under warranty. The following month the machine started leaving water in the base of the unit after the wash cycle was complete. LG claim it is an electronic fault in the circuit board. I have refused repair and am now claiming a replacement with them. I don't feel it is acceptable for a machine that's only 3months old to give problems such as these.
Mar 28, 2011 | LG LD-1420T1 Dishwasher
Whirlpool washer leaking oil from bottom. is it gearbox or transmission? is it worth repairing?
It is gear box. Rebuilt on ebay about $100. New on Ebay about $185. Washer has 13-15 ounces of oil. Unless you have a big puddle, keep using it.
Oct 27, 2010 | Whirlpool Washing Machines
Oil Leak-New washing machine
No sounds like you have a bad trans,but the good news is it's warrantied for the first year. call Whirlpool or register and schedule online
http://www.whirlpool.com/custserv/index.jsp
Sep 13, 2009 | Kenmore 3.2 cu. ft. Top Load Washer
My Washing Machine 13 month old, was repared 1
Likely the ECU is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Washing Machines
HOTPOINT aquarius WF541G
most likely suspect is the heater. undo wires from heater and see if fault persists. if not, heater is down to earth and will have to be replaced.
another possibility is a leak causing some of the wiring to be wet
Jun 28, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Sal De
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
