Canon PowerShot S1 IS Digital Camera
Problem for Canon PowerShot S1 IS Digital Camera
Error 30
By Guest on Aug 31, 2005
I am getting the "E30" error code.
What can I do?
Solution #1
posted on Aug 31, 2005
Somewhat Helpful)
Fishi
Rank: Wiz  Canon Expert
Rating: 79%, 224 votes
The "E30" error code is displayed when reading/writing data on a storage card has failed.
Especially, the error code "E30" may appears when you tried to remove a storage card while the camera was processing data.
Solution
To clear the "E30" error, try performing the following procedure.
1. Try using another storage card.
If you have another storage card, try loading it in the camera.
If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera.
2. Use your computer's ScanDisk utility to check the storage card for errors.
Use ScanDisk to check the storage card for card error or card failure.
Refer to the instruction manual for your operating system or Windows Help for further instructions.
(If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.)
Be sure to back up the data on the storage card on the computer before you check the CF card.
If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the storage card.
Follow ScanDisk's on-screen instructions to solve the problem.
3. Format the storage card with your camera
Try to format the storage card with your camera.
Please refer to the "Camera User Guide" for your camera for instructions on formatting CF cards. Also, please note that formatting a storage card will erase all data on the card.
Once the storage card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the CF card for errors.
If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the storage card.
If turning the camera off and then on again, and then performing steps 1 to 3 above fails to clear the error, a camera malfunction may have occurred.
Please contact the retail store where you purchased the camera or the nearest Canon service center.
If the error code is displayed right after you took a picture, the image may not have been recorded. Switch the camera to playback mode to check if it was recorded.
Precautions for handling a storage card:
- Do not remove a storage card or turn the camera off while the camera is recording, loading, or erasing data on a storage card.
- storage cards are high-precision electronic devices. Do not bend, force, or subject them to shocks or vibration.
- Do not attempt to disassemble or alter a storage card.
- Place the storage card in the supplied case for storage.
- Moving a storage card rapidly between temperature extremes may cause condensation in the card, leading to potential malfunctions. To avoid condensation, place the storage card in a sealed plastic bag before moving it into a different temperature area and allow it to adjust slowly to the new temperature. If condens
You rated this solution as "Somewhat Helpful".
Popular Solutions for Canon PowerShot S1 IS Digital
Questions and Unsolved Problems for Canon PowerShot S1 IS Digital
Do you recommend Canon PowerShot S1 IS Digital Camera?
Answer
Answer
file format of images in cf card not recognized by any computer
Answer
I keep getting a black screen and cannot take photos: batteries are replaced, power light is on but... (More)
Answer
Flash problem. I have had my camera for a number of years with no problem. However it now will not... (More)
Answer
while in shoot mode my camera has a black screen with a small hand icon(as if to say stop). i can't... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital... Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
