Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Hi, can you give me few points to start from
The freezer is fine, the icemaker is working fine (no ice burning or extra moisture in freezer), but the refrigirator is warm, because an opening from the freezer gets coverde by ice (i think from cooler side, not from freezer side). if i turn everything off and de-ice, everything works fine for few days until the opening between the two compartments gets covered with ice. it looks like both doors get good fit without any air leaks. my basic analysis lead me to one of the following potential problems:
1. air leak someplace
2. failed temperature sensor in cooler compartment, the one next to fan
3. failed electronic panel.
Please let me know what you think might be the problem.
Thanks in advance,
Vlad
  • 291 Answers
First thing i need to know what kind of refrigerator you have..
Model # and make...
take a dollar bill and close it in the door gasket and see if you get a pull on the bill when u pull it out.. go along the whole door gasket like that and it will tell ya if your gasket got a leak anywhere...
Posted on Aug 24, 2008
Electrolux french door w/freezer in bottom stops making ice.have turned it off overnight but it will not start bsck. what can I do , I have used hair dryer to thaw it and that worked several times but...
You failed to give a model# so I can refer to which bottom freezer you have..
Electrolux can be a tricky product to work on and I do not know if you have the icemaker solely in the freezer, or if you have the icemaker in the refrigerator section with ice and water in the door. Or if you have two icemakers as some of them now have because the one in the fridge breaks so much.
Hair dryers are a bad idea no matter how you look at it.. Many times, I have gone to do a repair and found disfigured plastic parts due to the customer trying to fix it themselves off a youtube video. The plastic they use is good in the cold but becomes very pliable when heated and tends to distort easily.
So... If it is the one in the bottom (freezer section) then it could fall under a service flash regarding interior moisture building up around the evap fan blades. Or it could be a bad water valve depending on what it is that you are thawing out..
If it is for the icemaker in the refrigerator section then there has been numerous fixes for this with the most current being part # 5303918784 which also addresses interior moisture.
I have also found that the defrost heater for the icemaker evaporator goes bad for the icemaker in the refrigerator section and have replaced quite a few lately.
If you need more help, please give more information specifically the model#.
frigidaire-ffhb2740ps2-ice-maker-air-handler-housing-gasket-kit-genuine-oem-5dtrzrhacenyq0nfrt1kdhhl-3-0.jpg
Jan 29, 2018 | Refrigerators
ICEMAKER LEAKING WATER AT 2 POINTS ON RIGHT SIDE IN FROUNT AND IN BACK
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 23, 2010 | Frigidaire Optional Icemaker Kit
I noticed the freezer was not working as well as usual. The back wall of the freezer, by the ice maker (not hooked up) is very hot. What's going on?
The heater on the icemaker is staying on. Be very careful not to touch the bottom of the icemaker and remove it from freezer asap. Do not touch the bottom of the icemaker mold because thios will severly burn you. Take the icemaker out or the freezer wall will start melting.
Jun 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
We just inherited what looks like a 57029. We
No, but it is easy to disconnect icemaker. Unplug behind icemaker (remove or loosen screws to see plug. Put tape over jack in freezer to keep moisture out. Put icemake back when ready to connect water.
Aug 24, 2009 | Kenmore 57029 Side by Side Refrigerator
There is a burnt smell emanating from my freezer. The ice maker isn't making more ice. My freezer had been left ajar and there was freezer burn on several items. We shut the freezer and after two days I...
Pour about 1/2 cup of water into icemaker . If it dumps the cubes , then replace the water valve . If it doesn't , replace the icemaker . Also make sure the refrig coils are clean and free of dust , lint , pet hair , etc....
Aug 18, 2009 | Frigidaire FSC23R5D Side by Side...
Freezer not cooling/making ice.
At this moment I think that you need to unplug the refrigerator and remove the ice maker to stop the leaking. Any extra water inside the freezer will make it harder for the defrost to remove the moisture. While the ice maker is out I want you to look to see if water is still leaking out the fill tube that feeds the ice maker tray. If it is then we found the reason. If not then we need to check some of the parts on the ice maker. Let me know what you find, Thanks, Sea Breeze
May 20, 2009 | GE PSS26PSS Stainless Steel Side by Side...
HSS25IFMDWW- freezer frosting up but working
sounds like the defrost thermostat or you may have a crack in the water line causing the freezing.
Jun 10, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
I have a Whirlpool side by side refrigerator with a new ice maker. The ice maker works fine but will not drop the ice. If I cycle the arm off/on (up/down) then it dumps the ice a few minutes later. ...
Humm thats a good one, but I will try to help you out. First off you say the icemaker is new, so does that mean you bought the icemaker and installed it on the refrigerator. Or is the refrigerator new and it has an icemaker. If you installed the icemaker new on an older refrigerator you can have a few problems. Most likely the freezer is not getting cold enough for the icemaker to cycle on its own. Especially if you are peaking in every few minutes like I would be doing. The icemaker will start a new cycle when the temperatur hits 0 degrees. If the freezer is only getting to 5 degrees the icemaker will not cycle. In that case the problem would be with the refrigerator not the icemaker. If the freezer is getting to 0 degrees then you may want to take that icemaker back and get a replacement. Good luck and I hope I helped. mca0824@aol.com
May 02, 2008 | Refrigerators
Freezer Problem
The only thing I can think of is your icemaker heater is staying on. When your icemaker goes into a harvest mode, (dumping ice and then re-filling with water) there is a "U" shaped heater (located on the under side of the icemaker) that comes on to release the frozen cubes from the icemaker mold. If this heater is continuously hot, it will cause temperatures in the freezer to rise.
Oct 04, 2007 | Whirlpool GS6SHEXMB / GS6SHEXMQ /...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
64 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
