Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover agility carpet cleaner
I took all the screws out and still cannot separate the housing to get to the hoses! Please help!
Nancy
    Master:
  • 763 Answers
Mam try to put your model to download your manual below in this link. ill try to find other solutions for this.
http://www.hoover.com/CustomerService/Manuals/Default.aspx
CHARCOIS
Posted on Aug 26, 2008
  • 435 Answers
    Master:
  • 521 Answers
The plastic locks may be connected to it.please remove that plastic locks.its simple.
Posted on Aug 24, 2008
    Genius:
  • 1,847 Answers
Where exactly did you take the screw out from?
Hover f7458-400 carpet cleaner brushes wont turn
Based on the hints above I cleaned the filter as it was clogged. That did not fix it. Then I took a stout screw driver and used it to turn the square brush drive, The drive broke loose and I am in operation with no dis-assembly. Hooray!
Apr 22, 2012 | Hoover F6212-900 / F6215-900 SteamVac...
Describe your F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Problem the bottom hose is split. how do I fix that? more specifically..how do I get it out???
I took out all of the screws in the housing, separated the left side from the right from the handle down. There were three screws on the underside of the upper unit. (right where the tanks sit). O those were out I could finally get to the broken hose.
Aug 22, 2011 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover carpet cleaner brushes do not move
did you check to see if the belt came off or its stretched?
Jan 24, 2010 | Hoover F6212-900 / F6215-900 SteamVac...
How do you open a hoover steamvac agility to change the lower hose assembly?
ok. you will need a screwdriver phillips and a pair of ****. this is going to take about an hour. first take off the tanks, nexted on one side of the machine you will see i believe its 8 to 10 screws. (you don't need to take apart the handle) once you take all of them out, there's a plastic plate that the tanks sit on. take this off. (4 screws) got that done, seperate the two pieces.(the handle will come out so you have more space, it will be a tight fix) the haves are apart and you will see the hoses there. take out the big long hose(2 screws hold it on at the top) and at the bottom of this is the short hose that you need to replace. using your **** cut the plastic on either side of the notches on both sides. put the new hose on. then reverse your steps for putting back together. hope this helps out
Jul 18, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F6212-900
Press the handle release kick-button with your foot, extend the handle all of the way back, and take a look at the gap between the base of the unit and the handle/reseviour assembly. You should see several black hoses attached to the base and running up into the handle assembly. One of them (the dirty water return hose) might be cracked. Turns out that might be a common problem with this model. We had the same problem.
Judging by the interference between the vacuum hose and the "dirty water return" hose, there is NO WAY those two hoses can exist together in that housing without causing the dirty water return hose to stress. It certainly cannot last for many full bends of the handle.
We opted to not repair our unit, but you might be able to do it yourself for the cost of the part and several hours of your time. Otherwise, seek out your certified Hoover repair center for more info.
UPDATE: I McGuyverized it myself with a dremel cutoff tool, some vinyl tubing, some 2-part epoxy, and a lot of faith. It sure isn't pretty, but it sucks again. :)
May 30, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Replace interior hose for cleaning attachment for Hoover Steam Vac Agility
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=632107
Replace interior hose for cleaning attachment for...
Posted by castcomm on May 29, 2008
How do you dismantle handle to replace aforementioned hose?
Swing arm on unit goes all the way to the floor. Is this normal? Is there a "stop" broken that caused the hose to stretch, and ultimately break?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There are handle screws that you can get into the handle and then you can back track the replace the interior hose for the cleaning attachment. There should not be a stop that caused the hose to stretch ad break. The hoses after a while do get old crack and break due from normal use or if the bend @ sharp angles, this is common among all vinyl vacuum cleaner hoses. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
93 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
