Question about Oritron DAV3101 PROGRESSIVE SCAN DVD
Oritron DAV3102 No sound to speakers
I bought a DAV3102 about 3 years ago and it has worked fine for those years but about 6 months ago it stopped outputting sound to the speakers. What puzzles me is everything else works and it can still take sound in and output it out of the other sound out ports, just not the speakers. That would work fine if I was going to use those but I don't.
I guess what I really need to know is whether or not this is now junk or if there is a way to fix the amplifier in it. I have done a lot of searches on this and there is pitifully little.
  • harjan Oct 16, 2008
    Please let me know all the solutions/suggestions you got and how you solved this problem,. I also have same problem.
  • 4 Answers
I've looked into the Koss/Oritron 3102 issues. Unfortunately, the amplifier is rather fragile. Also, the output chips are connected so that if one fails or senses a problem, it will shut down the entire amplifier board. These are not supported by any one anymore, repair boards are unavailable, repairing the old board involves hot air reflow soldering, and Koss denies any knowledge of them. So, to make a short story long, they really aren't worth messing with, You could use the output from the headphone jack to drive a separate amplifier, but that's about it.
Posted on May 25, 2010
I have the exact same problem. It stopped working a couple of days ago. Let me know if you find a solution.
Thanks, Nicco
suavenicco@gmail.com
Posted on Feb 27, 2010
HELLO I BOUGHT A 60 INCH SAMSUNG SMART TV ESUN8000, 6 MONTHS AGO, AND I NOTICE THAT IT HAS 3 WHITE DOTS. WHAT CAN BE THE CAUSE OF THE PROBLEM? I BOUGHT THE TV AT BEST BUY, DO YOU THINK THAT THEY CAN H
sound like you have samsungs dlp white spots plague, which just gets worst. samsung are aware of the problem, so you need to get in touch under the warranty.
Nov 25, 2013 | Sony KDF-42WE655 Television
BATTERYS DIE AFTER 3 MONTHS, ON A FE500V?
The batteries in a FERRUPS typically last 3-6 years depending on how many power outages you have, how much heat there is, etc. So, 3 months doesn't sound right. Hopefully, you are buying batteries from a reputable source. Eaton bought Powerware about 6 years ago and retained their service network which has lots of techs trained on the FERRUPS. I suggest you contact them:
Toll Free: 1 800 356 5737
E-mail: SinglePhaseTS@eaton.com
Dec 14, 2010 | Powerware FERRUPS FE500 (FA000AA0A0A0A0A)...
Overloading
hi mate, ive had the same problem before with this amp. i bought it new aout 6 years ago and bought another new one about 1 year ago, new, for £70!
on the first amp there was a problem with the surround sound aspect, it kept overloading when turned up even a fraction, it would tick 4 times and power off. Eventually the surround sound stopped working all together and whenever selected made a VERY VERY loud hissing/crashing noise through all my speakers, blowing one of them, SO BE VERY CAREFULL.
when that happened i assumed was broken so bought another one, and had same overload trouble when i got a new speaker package.
Im pretty dam sure it was the ohmage ratings being different on 2 of the surround sound speakers that srewed the 1st one, so id suggest you check theyre all ok, as well as the speaker watt-age.
what are the specs on all your speakers (ohms and watts RMS)??
do you listen to LOUD music through the 5.1 option??
hope this helps, if all else fails buy a new one mate, theyre so cheap. go into panasonic shops and see if they have any left.
Apr 23, 2008 | Panasonic SA-HE7 Receiver
No sound on LCD tv
in the audio part of the menu, check to make sure the internal speakers are not turned off.
what connection are you using for the DVD? if using YPrPb, make sure you also have the audio red and white plugged in
Feb 12, 2008 | RCA L37WD12 37 in. LCD HDTV
Sound Fluxuation
When this happened to me, I trimmed the wire that came from the speaker to the dvd player. I had to much wire exposed and they were touching behind the machine.
Dec 20, 2007 | Oritron DAV3101 PROGRESSIVE SCAN DVD
GO VIDEO DVD + VCR model: DV 1130 I want only the basic connection
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
again be visible on a conventional analog TV or monitor.
Nov 07, 2007 | Televison & Video
DAV3102 not enough volume
I have a DAV 3101 and the sound level is much better if the optical input is used. If you use other then supplied speakers you can blow the unit up. It uses 50uF electrolytic capacitors inside the front speakers (3) TO SAVE SPACE IN THE MAIN BOX. However, my unit will shut itself off. Standby light flashes and won't turn on until line cord power is reset over nite. Too bad Oritron doesn't support their products. Their web site is poor. I couldn't find an authorized repair service. Buyer beware! Tom H
Oct 18, 2006 | Oritron DAV3101 PROGRESSIVE SCAN DVD
Televison & Video Logo
321 people viewed this question
Top Oritron Televison & Video Experts
Electro Med Services...
Are you an Oritron Televison and Video Expert? Answer questions, earn points and help others
