Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Idc gas trimmer model 530
How do you get the trimmer head off to add more string.
  • dianepitchfo Sep 01, 2008
    I can't get the head off to put on more string
SOURCE: Ryobi string trimmer 32.1 what do mix gas and oil or just gas?
Ryobi trimmers I have had use a 32:1 oil mix. Just pick up a little bottle of Ryobi 2-cycle oil and read it to see that it will give a 32:1 mix in a gallon of gas. Pour it into a gallon of gas, and maybe a little fuel stabilizer too, shake it up and you should be good for the season.
Posted on May 28, 2008
  • 8 Answers
SOURCE: how far does the return gas line on a ryobi string trimmer extend
There is supposed to be a barb fitting with a flange on top of it that is on the end of the hose, inside the tank. If you do not have that barb in place the gas will start to leak out of the tank in a short time. Barb fitting is designed to have hose stick up about 3/16" into the tank when the hose is properly installed. You put the new hose on the fitting, thread the other end of the hose through the fill opening of the tank and out the hole in the bottom. Pull hose through until barb comes through the hole in the tank and the flange is flush with the inside bottom of the tank. There is supposed to be a plastic ring that fits over the bulge in the hose/barb at the bottom of the tank on the outside. Serves as a retainer for the fitting.
Posted on May 20, 2009
smjdragonfly
  • 79 Answers
SOURCE: remove string trimmer head on ry30120
Just the head or the attachment? The piece on the bottom, the bump knob can be unscrewed, sometimes are left hand thread. The attachments are screw off also I believe. Some may have two little pegs you push in and unattach it. Hope this helps. Please rate me
Posted on Jun 18, 2009
woobie dog
  • 1273 Answers
SOURCE: how do you remove the head off of a string trimmer
It should pull straight off.
Best regards, --W/D--
Posted on Aug 18, 2009
heatman101
  • 43501 Answers
SOURCE: Trimmer is not getting fuel,
Click here
I think this will give you the info you need to fix that...
heatman101
Posted on Jul 14, 2011
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do i disassemble a craftsman string trimmer head to expose the trimmer shaft?
you dont,y7ou need to get the adapter that came with the universal head,if you try to take more than the head off,you will damage it
Jul 19, 2015 | Craftsman Convertible 25cc. Gas Line...
How to remove trimmer head
Just make sure you only remove the string and cap. Then get a kit which comes with a cone to put over the remainder of the old head. You may be able to get the kit @ sears.
Jun 24, 2013 | Craftsman Convertible 25cc Curved Shaft...
Change head on trimmer
you buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
Mar 21, 2013 | Troy-Bilt 25 CC Gas String Trimmer TB22EC
How to feed trimmer line on y25 yard trimmer gas
Depending on what type of string head you have. If it's a "tap and go" style head, just rev it up full throttle and tap it on the ground. It should feed the string out and the blade on the shield will cut off the string to the correct length.
Sep 22, 2012 | Yard Machines Gas String Trimmer Y25
Need to replace string in RTE115C, instructions feeble Checked everywhere...ready to trash and buy some other brand.
Oddly enough, the string head appears to be identical to the one for their gas model. Some poor engineering and design here. Before you buy another model, maybe take a trip to Home Depot and in the lawn and garden section you may find several trimmer parts for different models, including a Universal String Head. Try changing out the head as the stock one is a headache for many users.
Nov 19, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Troy built 27cc string trimmer Model TB21 EC. What is the gas oil mix ratio?
4 cycle engines do not run on mixed fuel. Run on straight fuel. They have a spot to put oil in just like a lawn mover, and should be changed regularly. @ stroke engines run on mixed fuel.
Sep 27, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do you remove the old string head to add replacement?
untwist the nut at the bottom of the spool head to replace the string
Aug 30, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do I get the head off of the trimmer?
There should be a round knob at the bottom of the spool where the string is. Twist off counter clockwise and the spool of string will drop off.
Jim
Jun 20, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
How to add more line in my craftsman 32cc
Invert the trimmer pull the center of the head straight off. Wind new line in counter Clockwise direction. There should be a hole or notch to place the center of the string in. insert each end of the sting through one of the holes in the head and reinsert the spool into the proper position. Be sure that the automatic advance is movable by pressing down and pulling out more string. Cut string to proper length and restart your trimmer
Jun 06, 2009 | Craftsman 25cc Gas Line Trimmer
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
522 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
