Question about Lexmark Office Equipment & Supplies
It wont print - Lexmark Office Equipment & Supplies
    Problem Solver:
  • 9 Answers
Hey mr /ms
i hope i can be helpfull ..so plez tell me if the solution doesn t work ..and don t forget to rate me plez
Solution #1: Check the power cord at both ends. It might have been pulled out of the wall when you vacuumed last week, or the end that plugs into the printer might have come loose. If it did, plug it back in. If this is a new installation, make sure you didn't plug it into a power outlet that's connected to a wall switch. If the outlet is mounted upside down (the ground plug or "third prong" is at the top), it's a switched outlet.
Solution #2: It might be a blown fuse on the power supply. All dot matrix printers have fuses, and on most printers, the fuse is located next to the power cord under a small black cap that you turn slightly and then pull off. If it is the fuse (you'll see a melted piece of metal inside), replace it with the exact same fuse type. Radio Shack and your corner electron...
Posted on Aug 23, 2008
Lexmark x1150 wont print text but will print pictures
In this case what i would Request u to do is.........
Goto Control Panel goto Printers folder.........
There u will see the Lexmark Printer Icon...........
Just right click on the Printer Icon and click on Properties.........
Now click on Advanced and goto Print Processor.........
Change it to Lexmark NTEMF 1.0008........
Click on Apply click Ok now try to Print..........
Prints Fine............Issue Resolved........
Same Problem........
Download the Lexmark ToolBar from:
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1255995709_0_en,00.html
Restart your computer once and now try to print using the Lexmark Tool Bar..........
It should work fine........
Good Luck..............
Apr 18, 2013 | Lexmark X1150 All-In-One InkJet Printer
Epson sx215 wont print pdf files
You need to clean the print heads first - if they are blocked they won't print.
Clean them several times - then try the print check.In Case You Still Having Problem Then Follow Us For On : Epson Printer Support
Sep 20, 2012 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Flashing red light wont print last cou[ple of days printing black lines every now and then and now wont print tried putting new roll in still wont work
Autosence your printer by turning it off and then hold down the feed button while turning it on and release feed button when light flashes red.
May 15, 2010 | Zebra TLP 2844-Z Thermal Label Printer
My hp7200 wont print color
Your printer wont print paper because you need to put color paper in your printer
May 16, 2010 | HP OfficeJet t45 All-In-One InkJet Printer
I send the doc to be printed but the printer wont print it
first of all reinstall the printer driver, if it doesn't work try changing of USB cable.
Aug 13, 2009 | Epson Stylus C46 InkJet Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Wont print 2 colors, only black and white
The print driver might be defaulted to black and white. Change it to color.
May 27, 2009 | Ricoh Aficio AP3800C Laser Printer
WONT PRINT
I had the same problem, would print from PC, but would not from Fax, changed toner cartridge and all works fine, it's like when it's says it need ink it's not kidding.
Feb 10, 2008 | Canon LaserBase MF5750 All-In-One Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
