Question about Sony KV-27S42 27" TV
Sony kv-27s42 no picture no sound can here relay click
Standby LED blinks the following code: 3 quick blinks and 1 long blink. Note, I have no service manual.
  • 4,234 Answers
I will look up your specific model to be sure, but teh 3 blinks usually mean a power supply problem. Stay tuned for more...
Dan
Posted on Aug 25, 2008
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
No picture no sound. Red led blinks once relay clicks once and repeats
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 25, 2014 | Sony KV-XF34M65 34" TV
MY TV TURNS OFF 1 TO 7 MIN. AFTER TURNING ON. THE STAND BY LIGHT BLINKS 2 TIMES THEN A PAUSE THEN BLINKS 2 MORE TIMES
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 06, 2011 | Sony KV-27S42 27" TV
My sony trinitron model kv-27S42 has no picture/sound, keeps clicking and the Stand by/Timer light keeps blinking. I have disconnected it for the night, plugged it back in but the problem remains? any...
Hello
Blinking of standby light in Sony TVs are fault indications. You just count the exact number of blinks occurs at a time after switch it ON. Switch it ON and OFF by its front panel power switch, and not by the remote control handset. Do this for at least four times, count the number of blinks, confirm and inform me. I can then locate the fault section of your Tv, seometimes even to the exact point of fault too. OK
Happy New Year
Dec 31, 2010 | Sony KV-27S42 27" TV
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony-27S46 TV standby light flashes 4 times
Can you please confirm the model number? The category is for KV-27S42 and you state in the title you have KV-27S46. Also, when getting the 4 blink code, do you see a horizontal line on the screen or nothing at all? The 4 blinks means no vertical sweep. This can be a bad vertical IC (what you changed already) or no power to the IC or even a bad capacitor in the same circuit. If you know how, check the supply voltage to the IC. If not present, we need to trace the supply line for that IC. I will need to consult the service manual to provide additional details. Please confirm the model so I get the correct part numbers etc.
Thanks,
Dan
Jan 14, 2009 | Sony KV-27S42 27" TV
Sony triton kv-27s42 blinks four times won't turn on
ask rent a center to send it to their service dept in their city it will get fixed for a small price unlike some of your local tv reapair shops that will bust your head and pocket book (price) just to come take a look at it
Dec 20, 2008 | Sony KP-46WT520 46" Rear Projection...
Sony KV-27S42 no sound and audio blinks four times
+13 & -13 requires for Vertical Deflection IC and produced by Flyback Transformer, these volts will be produced IF Horizontal deflection circuit works properly. so try to check H-Out Transistor and its necessary volts / signal. Pls also mention correct Model Number to provide you more help.
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
No power black screen standby light flashes
Hi, Most new Sony TVs have a built in self-diagnostic feature. One of the led lights would be blinking. The number of blinks (on/off) is indicative of a code. The code represents a system fault. For example on some versions, 3 blinks indicate diagnostic mode where the builtin protection has kicked in (very likely a powersupply problem). How many blinks is the standby light doing? Due to the technical requirements to repair this TV, you would probably require the services of a qualified TV professional very familiar with Sony models. You can try a hard reset by unplugging the unit off from the mains for a couple of hours. If a no by then, we're back to the tech. Good luck and kind regards.
Aug 26, 2007 | Sony KV-27S42 27" TV
Sony KV-27S42 27" TV Logo
273 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
