Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Error 18 I am getting the "e50" error code what can i do?
As the lens on my Ixus IIs would not retract and the screen displayed the error "E18" I gently wiggled the lens the hit the on button. The lens retracted and the camera become operable. So, thanks for the hint above.
Posted on Sep 17, 2007
    Sergeant:
  • 255 Answers
The "E18" error code indicates an error that involves the lens unit or lens cover. This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area: - Hold the camera so that your fingers do not touch the lens unit when you are shooting. - Make sure the camera is off before you put it back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
Posted on Aug 31, 2005
4 Suggested Answers
Fishi
  • 255 Answers
SOURCE: Error 18
Fishi
  • 255 Answers
SOURCE: Error 50
The "E50" error code indicates formatting a storage card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another storage card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other storage card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the storage card for errors. Use ScanDisk to check the storage card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the storage card on the computer before you check the storage card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the storage card. Follow ScanDisk's on-screen instructions to solve the problem.
  • 130 Answers
SOURCE: Error 18
This is a common problem not with just canon but any auto focus camera that uses gears and a motor to zoom or focus. There are 2 basic problems for this error. E18 is the error that tells the user that the lenses are stuck and they can be cause from an impact or debris in the teeth of the gears. Its unavoidable, canon has tried to prevent this using gaskets around the lenses but over time the gaskets just wear and then debris can slip past the gaskets. The impact is a user problem. The gears are plastic and plastic can take only so much force before it breaks. The only way to prevent it is to buy a camera that does not have an optical zoom so you dont have any moving parts. You then lose some features. Try to avoid dusty sandy enviroments, keep the camera stored lens down and dont drop it. The lens is glass, glass is fragile it can break.
Posted on Mar 23, 2006
AEG Lavamat 60810 keeps stopping and displaying error E50 and some time E70. What is the problem and how do I fix it?
Family error code E50 means a problem with the washing motor. Family error code E70 means a problem with the NTC sensor. In my experience, E50 is most common fault in worn carbon brushes. But in any case family error code E50 is shown to the customer. In service mode could be: E51,52,53 and 54. The same applies to family E70 error code that will be displayed in service mode as error code E71 or E74.
E50 error code could be: motor winding, power board, tachymetric generator, motor relay on power board, wiring between motor and power board and wiring between tachymetric generator and electronic.
E70 error code could be: faulty NTC sensor, wrong position of NTC sensor or to much limescale on it and finaly wiring between NTC and electronic.
Dado
May 05, 2015 | AEG Washing Machines
SOURCE: E50 what does it mean, Hello & Welcome to FixYa E50 in your Electrolux is a motor error and is displayed due to a bad motor or a bad motor capacitor. Check if the motor brushes are ok
Hello Baldur Thor, thanks for your inquiry!
From what you have described your Electrolux air conditioner is displaying an "E50" error code. I do not show an "E50" has a valid error code. Could you please verify which appliance you are having issues with? Additionally, you could perform a reset on your air conditioner which is disconnecting the power from it for ten minutes. If you continue to have issues please reconnect. -Matt
Dec 21, 2014 | Electrolux Heating & Cooling
Electrolux front loader E50 error
Hello Friend, thank you for your post!
I see you are receiving an error code E50 on your Electrolux dishwasher. Is it possible that the code is missing characters? Could it possibly be an E50? May I please have your model number? The serial tag, which lists your model number, is typically located on the right side as you open the door. With this information I can further address the issue at hand. In the meantime, I suggest resetting your dishwasher. You can do this by flipping the household circuit breaker off for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your dishwasher continues to display E50. Thank you - Z.
Apr 12, 2014 | Zanussi ZWF1640 Front Load Washer
Electrolux EWF1090 front laod washer not starting cycle? Error E50 is dusplayed on panel, however product manual has no reference to error E50? - NEED HELP
e50 is a motor error code,, this could be the motor itself of the wiring harness or the main computer board
Jan 26, 2011 | Washing Machines
Error message E50 shows when the machine is switch on.
Zanussi washing machines can sometimes display error code E50. As John Lewis washing machines are currently also made by Zanussi some John Lewis washing machines can also display error E50.
Unfortunately this is not a "proper" error code and is not listed in error code lists. It's part of the motor fault error code group and is apparently displayed to customers but when an engineer enters a special diagnostic display the "proper" error code will be displayed giving more information.
However, there are usually only two error codes beginning with E5 which are E51 and E52, which are "motor power triac short circuited" and "no signal from the motor tachometric generator" respectively.
So if you have E50 displayed on a Zanussi or John Lewis washing machine it looks like a problem with the motor. However, the E51 "motor power triac short circuited" could be a fault on one of the PC boards as triacs are usually on printed circuit boards. This could have blown due to a short circuit somewhere else (like the motor for example) - I would advise that an engineer is required if you can't see anything obvious with the motor.
Jan 09, 2011 | Zanussi ZWF1430W Front Load Washer
Error code E50, what does this mean? We select programme, all the lights are on, we press start and E50 appears. What does this mean?
e50 is a motor error code.check the motor brushes are ok and check the insulation on the motor as this will give you an e50 error code.could also be a faulty wiring loom to the motor or a faulty main control pcb
E50 says the motor is overheated, they recomen you let it sit for 30min to clear.
It can be the motor power supply triac has got a short circuit or there could be no signal from the motor tachometric generator, which will uaually mean a pcb fault, or wiring to motor or even the motor. hope this helps
Dec 13, 2010 | Electrolux EW1000i Front Load Washer
What does the error-code E50 means in a crayola Kiddycam 25070?
hi,
The "E50" error code indicates formatting a storage card has failed.I think the e50 error code happens when the camera is reading and/or writing to the CF card when the battery are dead or real low. The camera does not get to finish writing data and leaves an error on the CF card. Use new battery or fully charged battery. I hope this may help you,
regards,
kaybicks
Feb 27, 2010 | Cameras
E50 code
hiya
i'm sure that e50/e51 is the insulation in the motor breaking down, in which case its usually new motor time i'm afraid.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Jul 20, 2008 | Zanussi ZWF1640 Front Load Washer
Error 50
Aug 31, 2005 | Canon PowerShot S20 Digital Camera
Error 50
The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem.
Aug 31, 2005 | Canon PowerShot S1 IS Digital Camera
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
132 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
