Question about HP Photosmart 8250 InkJet Printer
Won't print except really faint color
I just bought all new ink for my printer and it won't print. I've cleaned the print heads, did test prints and even changed the black ink again! I don't know what to do...
  • csoldfield Aug 30, 2008
    All ink cartridges reasonably full, black quit printing, yielding really faint text. 6 colors still fine. New black cartridge did not fix. Cleaning did not fix. Barely a year old. Any suggestions?
Finally - continued to do further print head cleaning (about 6 times, included 2nd level) and finally started printing black again.
Posted on Aug 30, 2008
5 Suggested Answers
jaggujoshi
  • 119 Answers
SOURCE: I recently changed out my ink cartridges and was
Dear Sir,
I think you are usiing outdated catridge. Please verify that the manufacturing date of the catridge.
Cheers
Posted on Sep 19, 2009
  • 401 Answers
SOURCE: color and black ink is very faint I have run the
IN PRINTER SETTINGS CHANGE OUTPUT DPI
Posted on Mar 25, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: Printer shows it is printing and it just pulls
    A firmware update for your model addresses a number of issues including print quality issues. Please visit the Lexmark website to download and install the Lexmark S300 Series Firmware Update.
    Should the problem persists, please contact Lexmark Technical Support Center for additional assistance. Thanks.
    Posted on Oct 19, 2011
    TechyDrood
    • 2072 Answers
    SOURCE: black ink will not print but colors do
    Most likely culprit is a dried up ink within the nozzles themselves. The best things for getting rid of dried ink in the nozzles is to use either a standard bathroom cleaner or rubbing alcohol. With the printer on open the door as if you were replacing ink. With the ink cartidges visable, unplug the printer so they stay put. Remove the cartridge and spray the cleaner in the where the ink is taking from the cartridge and clean it with whatever works. I really really good trick is if you have an old cartridge you can use a syringe to fill up the empty cartridge with your cleaning solution or rubbing alcohol. Insert the cartridge and run some test prints. This will for sure run the cleaner through the nozzle and hopefully dissolve the blockage.
    Posted on Nov 29, 2011
    Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
    Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
    Mar 24, 2017 | Office Equipment & Supplies
    Won't Print Color Ink
    INK PROBLEM
    Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
    If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
    It may be more cost effective to buy a later model and better printer thanreplace the print head.
    May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
    Black ink will not print but colors do
    Nov 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
    My printer is not working properly. On the test page, not every line prints clearly.....faint and grey compared to other lines. Lines 1, 4, 8, ll, 14, etc. prints very light compared to the other lines. ...
    sounds like your heads are all gummed up with dried ink.Is this a older printer or previously used if so run the cleaner that should have come with your printer software. keep running it until clean or bring it to get cleaned.
    Feb 22, 2011 | Computers & Internet
    All colors print fine except for the magenta it is very faint
    Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
    Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts.
    Sep 17, 2010 | HP Color LaserJet 2600n Printer
    New cartiage very faint color
    Thanks for using FixYa!
    If you are getting faint print outs, try to clean the print head by going to the printer maintenance tool. If that doesn't help, make sure that the ink cartridge that you bought is genuine. I hope this helps.
    Have a nice day
    - HotRatchet
    Aug 18, 2009 | Office Equipment & Supplies
    I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
    What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
    You can try googling. Phaser printer print heads or phaser printheads.
    There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
    Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
    Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
    The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
    Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
    Very Faint Printouts
    I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
    Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
    Rgs
    The StickMan
    Dec 08, 2008 | Epson RX620 All-In-One InkJet Photo...
    HP Photosmart 8250 InkJet Printer Logo
    128 people viewed this question
    Ben Johnson
