Question about LG Televison & Video
I dont understand wy my lg tv is not recepting ....I can't watch TV anymore no more because I ha ve Only done an EZ scan
Lg 50pk 750 problempower
I wish you gave more details but i think i could be a power supply issue... If you have the courage to open the back cover of your tv, and you do "NOT" see any bad (bulging ) capacitors on the power supply, then it could be the voltage regulator. Take a look at the video i posted on youtube, then you will have a better understand why your tv is clicking... I'm also selling the repair kit for this power supply board on ebay now. LG power supply Board model number EAY60968801. With anyone of these PCB # EAX61392501/7, EAX61392501/10, EAX61392501/11, or EAX61392501/12 Please Make sure that you've already gone through the process of
troubleshooting and testing your tv's power supply board before making any purchases.. I recommend that you get a tv tech to check it out, because every tv is different. Email at bigthings09@gmail.com if you have any question.and watch the video:
http://www.youtube.com/watch?v=I9wF0OLyV0k&feature=youtu.be
http://www.youtube.com/watch?v=vHrv5XaDULI&feature=youtu.be
Sep 15, 2012 | LG 50PK750 50 in. Plasma HDTV
LG 50PK750 turns off as soon as I turn on
This issue is a common, but hardly talked about from LG. Your tv is probably 1 or 2 months out of warranty, and now you're hearing a series of clicks. ... If you have the courage to open the back cover of your tv, and you do "NOT" see any bad (bulging ) capacitors on the power supply, then it could be the voltage regulator. After weeks of fighting with LG to replace my tv, i decided to fix it myself. i'm proud to announce that my 50PK540 is now working. want proof? Take a look at the video i posted on youtube, then you will have a better understand why your tv is clicking... I'm also selling the repair kit for this power supply board on ebay now. LG power supply Board model number EAY60968801. With anyone of these PCB # EAX61392501/7, EAX61392501/10, EAX61392501/11, or EAX61392501/12 with the parts if this kit, I've also fis several 50PK750 models, Some clients have send me their broken power supply board, so I can do the repairs. Please Make sure that you've already gone through the process of troubleshooting and testing your tv's power supply board before making any purchases.. I recommend that you get a tv tech to check it out, because every tv is different. Email at bigthings09@gmail.com if you have any questions.and watch the video: part 1 & 2
Repair kit on Ebay
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200849231403
Youtube video PART 1 & 2
Jan 07, 2012 | LG Televison & Video
I have a LG Plasma 50PK750 that when you turn it on and goes right back off.
This issue is a common, but hardly talked about from LG. Your tv is probably 1 or 2 months out of warranty, and now you're hearing a series of clicks. After weeks of fighting with LG to replace my tv, i decided to fix it myself. i'm proud to announce that my 50PK540 is now working. want proof? Take a look at the video i posted on youtube, then you will have a better understand why your tv is clicking... I'm also selling the repair kit for this power supply board on ebay now. LG power supply Board model number EAY60968801. With anyone of these PCB # EAX61392501/7, EAX61392501/10, EAX61392501/11, or EAX61392501/12 with the parts if this kit, I've also fis several 50PK750 models, Some clients have send me their broken power supply board, so I can do the repairs. Please Make sure that you've already gone through the process of troubleshooting and testing your tv's power supply board before making any purchases.. I recommend that you get a tv tech to check it out, because every tv is different. Email at bigthings09@gmail.com if you have any question.and watch the video:
Dec 22, 2011 | LG 50PK750 50 in. Plasma HDTV
It has power, turns on then immeiately clicks off?
Aug 04, 2011 | LG 50PK750 50 in. Plasma HDTV
Tv will not turn on. Start to fire up then after about 1 second it shuts down. Never gets a chance to find a picture.
Jun 29, 2011 | LG 50PK750 50 in. Plasma HDTV
Need to retune free view as has never been done since buying
Hello
To retune your Lg tv, do the following. At first connect the antenna socket at its back side with antenna firmly.
hannel Search
Automatically finds all channels available through antenna or cable inputs, and stores them in memory on the channel list.
- Run EZ Scan again after any Antenna/Cable connection changes.
- A password is required to gain access to EZ Scan menu if the Lock System is turned on.
1. Press the MENU button and then use UP/DOWN button to select the SETUP menu.
2. Press the FORWARD => button and then use UP/DOWN button to select EZ Scan.
3. Press the ENTER button to begin the channel search.
Allow EZ Scan to complete the channel search cycle for ANTENNA, and CABLE
ok.
Jan 14, 2011 | LG 42PX5D 42 in. Plasma HDTV
Channel Memory
Don't use EZ scan,reset it to Factory Setting.Use Ch.set up go through the whhole process every channels should be there.
Dec 19, 2009 | LG 42LC2D 42 in. LCD HDTV
Connecting Rabbit Ears
If you are going through a VCR, make sure you have it in Port 1, or the primary connection. Sometimes they are sticking out the front and people use the alternate port at the back for tidyness, then it won't work.
Aug 03, 2007 | LG 26LX2D 26 in. LCD HDTV
Televison & Video Logo
64 people viewed this question
Henry  Thomas
Henry Thomas
