Question about Olympus Camedia Brio D-150 Zoom Digital Camera
Quality mode setting
How do I check the amount of images that I can take and the quality mode setting?
    Master:
  • 852 Answers
Press the monitor button. The amount of images that can be stored and the selected quality mode will appear in lower-left corner of the LCD display.
Posted on Aug 31, 2005
SOURCE:
Toshiba estudio 351c error code ce40
Hi
I hope that this will help you
[CE40] Image quality control test pattern abnormality
(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color.
(2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" to
check if the low-density pattern abnormality occurs for each color. The values under 320 for Y, M
and C, and under 220 for K are defined as low-density pattern abnormality.
(3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" to
check if the high-density pattern abnormality occurs for each color and identify the color which
pattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality.
(4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "0" (Invalid).
(5) Perform "Enforced performing of image quality open-loop control (05-394)".
(6) Output the image quality control test pattern (04-270) more than one time and check the patch of the color identified in step (3) to see if the image is abnormal.
(7) Replace the image quality sensor.
(8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "1" (Valid).
(9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it is
completed normally. (Error [CE40] does not appear.)
(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576).
Good Luck
Regards
Apr 12, 2011 | Toshiba Office Equipment & Supplies
I have just purchases a 8018. It is default set at 3 mp. I have downloaded the manual and followed the instructions to change mp to 8. However, when the camera is turned off it goes back to 3. Is this...
15
Image Size
The image size and quality setting determines the number of photos that can be saved and the amount of
memory required for each photo. The higher the photo quality the more memory it will use up. The image size
and quality will also affect the maximum size you can print your photo effectively. To set the Image size:
1. Press the Menu button.
2. Press Right/Left button to select the Image Size mode.
3. Press the Up/Down button to select the desired image size.
4. Press the Menu button to confirm, save and exit to standby mode.
If this still doesn't work, press the menu button twice.
Jan 29, 2010 | Vivitar ViviCam 8018 Digital Camera
Canon mp780 is stuck on fine mode and it will not
yes, first change the paper setting button to normal, then you can lower the image quality on copies.
Nov 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Image quality
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens.
This will allow you to focus the camera image on objects at different distances.
Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video.
Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed.
Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds.
If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter.
For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher.
To change the color palette please perform the following steps:
Click on "Start," "Settings," and "Control Panel."
Double-click on the Display icon.
Click on the tab labeled Settings.
In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost."
If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software.
To do this:
Open the QuickCam software.
At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
Choose "Advanced Camera Settings".
Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
Click OK when your are done.
Last, make sure that you ae using the latest drivers.
You can upodate them from here.
http://www.logitech.com/index.cfm/492/&cl=us,en?prodcrid=492
Hope this helps.
Good Luck.
Live, Love, Laugh.
May 11, 2008 | Logitech QuickCam Chat Personal Web Camera
Can't take photo's
There should be 2 settings, 1 for internal memory, 1 for external (card) memory. Internal memory is always low, especially if camera is set to high quality photos so only a few can be taken. check your settings on picture quality.
Jan 04, 2008 | Fuji FinePix S8000fd Digital Camera
Amount of images
Sep 01, 2005 | Olympus Camedia C-40 Zoom Digital Camera
Quality mode
Aug 31, 2005 | Olympus Camedia D-40 Zoom Digital Camera
E-mail images
What is the Macro function used for? The Macro function allows you to take close-up pictures. Use the Macro mode when you are 8.4” to 19.2” away from your subject. Where is the Reference Manual for the D-390? The Reference Manual is located on the Camedia Master CD-ROM and is available in four languages (English, French, Spanish, and German. The manual can be viewed on your computer screen or printed on your printer. How can I get traditional photo prints from my digital camera? Most photo processing centers or digital printing Kiosks can make traditional photo prints from a digital camera. There are also many on-line photo processors which conveniently deliver prints by mail. You can also make prints yourself if you have a photo quality printer like the Olympus P-400 printer. Why are there so many quality settings? Different quality settings are used for different purposes; for example, lower quality settings can be used to e-mail pictures because of its small file size. Higher quality settings are used for printing photo quality images. What settings should I use to get the best picture quality? The best picture quality setting on the D-390 is SHQ (Super High Quality). The SHQ file is the largest of all four quality settings. The image file size is approximately 786K. What is the video output used for? The video output is used for viewing images from your camera to a TV. A slideshow can be accomplished by using the camera hooked to the TV or recorded from a VCR. When taking macro images, can I use the viewfinder? Since the viewfinder sees the subject different than the picture taking lens, we recommend using the LCD monitor screen for taking macro pictures. The image previewed on the LCD monitor will be the exact image that is taken. How do I make a Panorama picture? You can easily make panorama pictures with your D-390 by “stitching” together multiple pictures. First, activate the panorama mode on the camera by selecting Mode Menu - Camera - Panorama. Take your pictures while making sure to overlap the edges of the images. Download your pictures to a computer and then use the “Panorama” function in Camedia Master to stitch them together. For more detailed information, please refer to the camera documentation. What is movie mode function? The movie mode function allows you to record short movie clips. The recorded movies can be played back or stored as still images using the cameras index function. Please note that the D-390 does not record sound in the movie mode. Can I add sound to a movie made with my D-390? The D-390 does not record sound in the movie mode. What is the best way to e-mail images? E-mailing pictures that were taken with your camera is as easy as attaching a file to your message.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
Quality mode
Aug 31, 2005 | Olympus Camedia Brio D-230 Digital Camera
Cannot set "HI" Mode to shoot TIFF Images
In order to shoot "HI" TIFF images first set the Image Size option to either "5M 2592x1944" or "3:2 2592x1728." Next, choose "HI" as the Image Quality option. "HI" is only available in one of the manual exposure modes (P, S, A or M) and is not available in the "Auto" shooting mode. If "HI" is selected and the camera is switched to "Auto" the Image Quality will automatically switch to "FINE" mode and a JPEG image will be recorded. Additionally, "HI" is only available in "S" Single frame Continuous shooting.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Olympus Camedia Brio D-150 Zoom Digital Camera Logo
41 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
