Viking DFSB483 Side by Side Refrigerator Logo
Posted on May 28, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My ice breaker does not work. I waas advised by a Viking repair man that my ice breaker module was the problem. So, I bought a new module and insdtalled it. The ice breaker doesn't work still The Viking guy says there are three power buttons (on/off) buttons in this freezer, onme of which is the on/off buttom that powers the ice-breaker. I cannot find them inside the freezer. If there is such a power butoon for this freezer, where is it ? Will it kick-start this new ice-breaker module?
brokenrubber
Level 2:
Habit-Forming:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 103 Answers
  • Posted on Nov 15, 2017
brokenrubber
Expert
Level 2:
Habit-Forming:
Night Owl:
Answers
103
Questions
0
Helped
41514
Points
174
Switch is cube ice or crushed ice
when you say ice brear does not work ?
do you mean no crushed ,no cube, no dispense at all or no ice production ?
3 Related Answers
Anonymous
  • Posted on Sep 28, 2008
SOURCE: Viking all refrigerator
I just started having the same problem with my 48" frig/ freezer Viking Designer series 2 years old- this has been a hot summer, we were not home much and the AC in the house was set higher 78 degrees so the frig I guess had to work a bit more - when I open the door to the frig water droplets acually run down the interior of the door and the box insde is always damp - I also have stress cracks in the interior shell of the frig - repairman is trying to get Viking to fix it- it has been a year now and it still is not fixed- the stress cracks were caused by improper insulation application to the inside of the frig according to the repair people- Also my handles have pealed - like the stainless steel is not really stainless steel - Any ways could the temp in the house changed - does not mean the frig should not work well - For what it costs, I expected better
Anonymous
  • Posted on Dec 13, 2009
SOURCE: 48 " viking ice maker tray frozen no ice
Try replacing
the icemaker unit. I used Supco model RIM943 and its working great. Found it online for $55 on line.
My Viking 48" ice maker has given me a little trouble too. The first ice maker assmble was replaced under warranty. It only came with a one year warranty so when it just went out again I thought I would take a look. Just like you I had no ice. It only take two screws to remove the ice making unit and a quick discount plug. I read up on the unit to trouble shoot it. My Ice maker had the ejection forks stuck in the down (in the ice cubes) postion indicating the unit was out of sync and needed to be completly replaced.
On another note:
I also had a proble with the flapper ice cube door on the outside ice dispenser. Ice cubes would get stuck in the door and would not drop into the cups. This was a lot tougher to fix, but I like figuring things out. Turns out I had some ice that got stuck in the flapper and some how it melted and froze back up to lock the flapper. When the motor came on it sheard a shear pin in a coupling just off the drive motor. I made a home made shear pin and put it back together and all work great now. It was a bit of work to take it all apart and to tell that the motor was good and the relay was working right.
Anonymous
  • 4793 Answers
  • Posted on Jun 02, 2010
SOURCE: Still leaks
it is condensate from the auto defrost bin/drain pipe,locate and clean with clorine bleach(stops nasties growing....)
1helpful
Viking built-in refrigerator/freezer:tube that fills the icemaker is freezing, so ice maker not working. Tech says because hooked up to RO, advised up pressure to 50. Of note, non-factory ice maker
The reason the fill tube freezes up is because the water valve is leaking by. 50PSI should be enough pressure. You most likely need a water valve.
Where will I find a new circuit board in the UK, for my 30yrs+ machine & a specialist repair man. Tried A1 sewing machines but they haven't got one.
Have your authorized Viking dealer procure a replacement board from Viking or perhaps get a board from a used machine that another dealer might have. Failing both options above, purchase a newer Viking sewing machine.
How do you replace the ignition module on stove.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
2answers
\i have a viking 190 sewing machine..it was put
throw the machine away I had a riccar machine I had to throw away for the same reason I bought it used in 1983 and could not get it parts it needed
1helpful
I have a side by side refrigerator that is 5 years old, and the ice maker does not work. We purchased a 5 year warrenty from Best Buy and requested warrenty repair. It took 3 weeks to get the repair part...
The ice makers are rather finiky. limit switches for almost every movement. Sounds excessive, but replacing the ice maker module will save you a lot of worries. The signal to fill with water comes from the icemaker when it is in the correct position
2answers
Ice maker stopped working. The water is cool, the filter is new. Dispensing water, but no ice.
It sounds like the solenoid valve has failed. This is what regulates the water to the ice maker. Have it replaced and that should take care of the problem. Hope this helps. Good luck.
Multiple sparks when igniting one burner
have a 1997 model 2470 viking pop up camper , has a shower in stalled where does the used water come out ??
1helpful
2answers
Viking professional 30 inch, sparking problem
If you have replaced the spark module with the new, blue PA020041 Tytronics 0+4 spark module, the physical positions of the leads that go to the burner igniters are reversed compared to the positions on the old, white module. Make sure that the switch wire for the burner and the position of the spark wire both go to the same burner! The positions are marked on the white label with green lettering.
2answers
Garmin gpsmap 162 turns on, works for about two minutes, then a thin black vertical line comes across screen and screen goes blank with the line remaining. I have to unplug and start over. Same things...
Possible Solution found on google....
My old Garmin 162 chartplotter was mounted on the binnacle guard and served me
well for many years. Lately, it started getting very slow to refresh screens.
At times, it would shut down with only a black vertical line on the screen. On
our last cruise, the screen froze at a very critical moment. Too old to
repair, I bought a new Garmin 440, which I am very disappointed with, but
that's another story.
I read an article in the GoodOldBoat newsletter about the Department of Defense
making changes to the WAAS satellites that have caused problems in Garmin 72
and 76. Garmin's tech support recommended to turn the WAAS function off on
affected units. So I got out my old 162 and turned the WAAS off and it works
fine. To make sure it wasn't a fluke, I turned it off and on several times,
and it always slowed down with WAAS turned on. With it turned off, the
position error or accuracy, increases 1-2ft, not a big deal. I hooked the unit
up on my truck and drove around. Not a problem. Further reading indicates
that other brands of GPS are also having problems with the new WAAS
transmissions.
So if you are having problems with your GPS and it is new enough to have WAAS,
try to turn it off
Sep 28, 2008 • Garmin GPS
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
john h
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
