Question about Curtis DVD6041 System
No picture my boyfirnd changed a setting on the dvd player, ( he thinks is the Video Output) and now we have no picture.
  • 4 Answers
Try changing the settings back to factory default. Both of my surround speakers stopped working, and doing this brought them back. If your remote functions properly, it can be done by hitting this exact sequence when in the DVD mode:
Setup>Right Arrow>Right Arrow>Right Arrow>Right Arrow>Enter>Down Arrow>Down Arrow>Enter
Note: The Arrow buttons are the ones that surround the Enter button.
This is a very poorly designed system, and the remote will not work from slight angles. You must be directly in front of the unit for the best signal reception from the remote.
Posted on Feb 15, 2009
How do I turn off pscan on a rca dro2oon DVD player
IMPORTANT:
If you don't have a Progressive Scan TV or you don't have the DVD player connected to the correct Input Jacks, and you activate Progressive Scan in the DVD player you won't see a picture! Don't panic-try the following:
First, press the PREV/VIDEO button on the front of the DVD player (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If that doesn't work, press and hold PREV/VIDEO button on the front of the DVD player for 3 seconds. Now, press the PREV/VIDEO button again (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If you still don't see a picture on your TV screen, make sure the yellow cable (provided) that is attached to white and red cable (called audio/video cables) is connected to the DVD player's PREV/VIDEO jack and the TV's Video Input jack. Change your TV channel to your TV's Video Input
channel that activates the TV's VIdeo Input jack where you have connected the yellow cable (page 9 of your manual has more information).This PREV/VIDEO jack on the DVD player always outputs interlace video, so you should see a picture on the TV screen.
As a last resort, you can reset the DVD player to the factory default settings:
Press and hold the STOP button on the remote control and the NEXT button on the front of the player at the same time - wait at least 5 seconds before you release both buttons
Sep 25, 2016 | RCA Televison & Video
Hello, I cannot change my picture from 4:3 to 16:6. The mode "change size" is not working. I cannot stretch the picture. Wolfgang, Germany w
hi,
You have to set the out put video format of your dvd player also to 16:9. For that go to the menu of your dvd player and serch for video output seting and set the output as 16:9.
Even if you select 16:9 option in the projector if the video out put of the dvd is 4:3 , then the projector will automatically change to the 4:3.
ok
Jul 30, 2011 | Sharp Educator Series XR-10X DLP Projector
I was using my dvd players component outs for a year but my hi def tv died so when I hooked up my old tv to the single video out I can't get any picture out of it. I think I need to get into dvd player set...
If its an old Sony dvd player then check Progressive Scan button at rear or some may have it on front to turn off to get composite video output (yellow video out)
And if it does not have any manual switch for progressive scan then turn off dvd player by pressing power button on its remote control, press 3, 6, 9 on dvd remote and press power to turn dvd player On.
That will turn off / disable progressive scan mode and you will get video output from yellow video out jack.
Jul 31, 2010 | Sony Televison & Video
No picture
change the tv selection to av and check till the dvd reappears
Nov 15, 2017 | Samsung DVD-V4600 DVD Player/VCR
Oritron dvd 3119 player
after unsuccessfully trying to naviagate the menu , i unplugged the dvd player for 10 or 15 min. then plugged it in again and changed the output i had it plugged into,,from video 1 to video 2 and i got my picture back it seems fine now
Apr 03, 2008 | Oritron NPD3117 DVD Player
Changed Video Output Setting
Reset you player by doing the following:
With the player on, hooked properly to your television1.gif, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 27, 2008 | Cyberhome CH-DVD 300 DVD Player
HOW TO RESTORE PICTURES AFTER SCAN
Look for a button on the remote control that says 'video output, video output mode', or something similar. If this doesnt work. Make sure its properly hooked up. Of that still doesnt work, get out the old dusty manual and take alook at how to change this. if it gives youa graphical pic in the book on how to do it, follow the pic by counting the rows and pressing the button on the remote. Or if there is a way to restore factory defaults do it,
Dec 30, 2007 | Cyberhome CH-DVD 300 DVD Player
Changing to PAL format...
i have the same issue i don't know the solution to ur original problem of B&W.. I think you might have unknowingly changed the "Video Output".. don't worry...to change it back.. do the following steps 1) Switch on dvd player with no disc 2) wait for few secs and press setup on remote 3)press -> (rt arrow) once 4) press enter 5) press down arrow twice 6) press enter 7) press up arrow once(or twice) 8) press enter hopefully this shud work..
May 05, 2007 | Cyberhome CH-DVD 300 DVD Player
Black & White picture
There can one of two problems here. Either your DVD player's output is set to NTSC and you are attempting to play it through a PAL (European) TV, or you are perhaps using the SVHS output incorrectly. The solution is to access the player's setup menu and ensure the video output is set to your standard (PAL or NTSC). Hope this helps!
Feb 14, 2007 | Philips DVP642 DVD Player
Curtis DVD6041 System Logo
130 people viewed this question
Top Curtis Audio Players & Recorders Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
240cpa
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
