Question about Nintendo Super NES Console
SNES problem I just bought a snes, but when i turn it on with the game B.O.B the screen turn green and purple then turn back to the original menu. then back. and then freeze when the screen is green and purple. ( the green and purple are thick lines rolling over the screen)
  • Nintendo Master
  • 424 Answers
Make sure you are using only licensed accessories with your system.
We find that video problems occur most when an unlicensed RF switch is used. Make sure the name "Nintendo" is molded onto the RF switch, as opposed to "for use with Nintendo." Unlicensed products are not fully compatible with our systems and may not work correctly.
Check all of the system connections to verify that they are firm and correct.
For AV connections
Remove the AV cables and reinsert them with a slight twisting motion
For RF connections
Make sure the channel switch on the TV and system are set to the same channel (either CH3 or CH4)
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to make sure it is locked in place.
Important Note: Removing the Game Pak with the power ON will cause the Game Pak image to freeze on the screen. Press Reset to correct the problem. Always turn your system OFF before inserting or removing Game Paks.
Slide the Power Switch on the Control Deck to the ON position.
If the above troubleshooting doesn't fix the problem, see below.
What to do if Troubleshooting Doesn't Help
Posted on Jul 28, 2013
latino
  • 93 Answers
SOURCE: My snes won't read games
have u try cleaning the connectors on the game with alcohol
Posted on Oct 29, 2007
  • 20 Answers
SOURCE: snes controller
It is common for buttons on any video game controller to quit working and it is usually an easy fix.
Assuming the cord is in good condition the problem is internal. Turn the controller over with the buttons down and remove all of the screws on the back. Carefully lift off the back. You are now looking at the back of the circuit board. Look closely at how the cord is routed through the plastic pins as you will have to put it back in the same location. Remove the cord from the pins and carefully lift out the circuit board. Turn the circuit board over and locate the contacts for the buttons. There are four on the left side for the D-Pad, two in the middle for the Select/Start, and four on the right for the A,B,X, & Y. These contacts need to be cleaned. A hard eraser works best. Reassemble everything and it should work fine for quite some time.
Posted on Jan 20, 2008
SOURCE: Vertical lines show up on my SNES picture of any game.
Do you have a third party AC adapter for it? If you aren't using the original one, check its voltage. Mine was a 9V instead of a 10V and while it allowed the machine to run, I got visual distortion effects similar to what you describe. If it isn't a 10V adapter, go to Amazon and get a real one instead of a cheap third party one. I got this one (http://www.amazon.com/gp/product/B00009ZKWC) and it works great!
Posted on Apr 10, 2009
  • 35 Answers
SOURCE: i was playing a game on my snes and it was working
The ac adapter might be breaking then you can buy a new one at lukie games. Thats were I buy my nintendo stuff.
Posted on Apr 05, 2010
  • 532 Answers
SOURCE: I am trying to get
Try the game with another TV to see if you will have same problem. If you do not have that problem that means the TV you are using is faulty.
Thanks for contacting Fixya.
Posted on Jul 06, 2010
Snes doesn't read games
Well it sounds like the console it's self needs to be cleaned out then 4.5 mm bit screw driver to open her up lukue games sell those 4.5 mm game bit tool compressed air to clean it out and it should work
Sep 29, 2012 | Nintendo Super NES Console
I am trying to get my old snes to work I plug everything up and when i turn it on the tv goes to a black screen i am using the original rf adapter that came with it model no:nes-003 nintendo rf switch. I...
Jul 06, 2010 | Video Game Consoles & Games
Snes -horizontal white lines and buzzing noise
the best bet is to obviosly try another rf cable or try anothe snes unit.
Jul 06, 2009 | Nintendo Super NES Console
SNES not working with Street Fighter Alpha 2 (graphic chip)
I'm not sure what a pin card is, but my best guess is that the game is dirty?
Apr 29, 2009 | Nintendo Super NES Console
Dead RF-out on SNES and vertical lines on Multi-out
The problem is likely in the IC soldered to your SNES circuitboard. The cheapest way to solve your problem is to replace the whole SNES circuitboard. These boards run about 20 dollars, Google part SNSPT007 or SNSPT009, depending upon if you have the older or newer version SNES. There is no soldering involved, so it should be an easy fix if you can open your SNES.
Apr 19, 2009 | Nintendo Super NES Console
SNES doesn't display?
The CIC chip, also known as lock out chip, may have gone bad. Here is a quote from a site I found.
"Every SNES control deck has a regional lockout chip (known as a CIC), as does every original SNES game cartridge. Before a game is loaded, the console will attempt to communicate with the CIC chip on the game cartridge. If the CIC chip doesn't respond or does not correspond with the consoles CIC, the console won't load the game. In most cases, a black screen is displayed."
http://www.chronicgames.net/articles/snes-museum.aspx
Yea basically I am having the same prob with my system and I am trying to fix it. Ill let ya know if i figure it out
Jun 14, 2008 | Nintendo Super NES Console
SNES Game/System incompatibility?
check your connections, try cleaning your snes system with some rubbing alcohol (the party where the game connects to the system), you might have to take it apart to do that...
one way we use to do with the NES was cut a piece of paper out to fit inside the game, make it wet with rubbing alcohol, then push the game in and pull it out a few times (of course if the paper gets stuck you'll have to take it apart to get it out.
SNES's are pretty cheap so u may have to purchase a new one
Jan 06, 2008 | Nintendo Super NES Console
SNES FUZZY PICTURE
check the aerial cable
Oct 26, 2007 | Nintendo NES Console
Nintendo Super NES Console Logo
155 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
