Question about Hitachi 43F300 43" Rear Projection Television
X480306 for Hitachi 43F300
Partsstore.com does not show this convergence kit as compatible for my TV.
  • Hitachi Master
  • 5,138 Answers
Replace both STKs 392-110s
Posted on Sep 11, 2008
Blue line
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 28, 2009 | Hitachi 43F300 43" Rear Projection...
Ghosting or distortion on edges of screen
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 26, 2009 | Hitachi 43F300 43" Rear Projection...
Convergence problem
it sounds as though you need to have the tv converged
Oct 30, 2008 | Hitachi 43F300 43" Rear Projection...
Hitachi 43F300 convergence
Do not replace whole convergence board.Because convergence data stored in old board cannot transfered to your new board.Means in your new board there is no convergence data.Unless you have the service manual and know how to get service menu.
I believe if you have convergence problem one of your IC (STK) is bad along with couple of small
Value resistance.
Dont forgat to Rate!
Good Luck
Dals123
Oct 21, 2008 | Hitachi 43F300 43" Rear Projection...
43F300 convergence
Convergence kit # X480306 for your Model #.....
Replace parts & activate auto-focus......T.
Sep 01, 2008 | Hitachi 43F300 43" Rear Projection...
43F300 convergence
convergence kit # x480306 , dont go into the service mode unless you know what your doing in there and what your adjusting./st.
Aug 22, 2008 | Hitachi 43F300 43" Rear Projection...
Hitachi 43F300 43 in. Rear hrojection TV
you possibly have a deflection or convergence fault.
Jul 27, 2008 | Hitachi 43F300 43" Rear Projection...
(Hitachi 43F300) Turning its self off
Sounds like it is going into shutdown mode. When the TV power supply and system control sense an overload the system control turns the TV off to prevent further damage from happening. I suspect it is a shorted convergence IC. It would be best to call a service center to repair the TV.
May 18, 2007 | Hitachi 43F300 43" Rear Projection...
Hitachi 43F300 43" Rear Projection Television Logo
93 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
