Sylvania LC 155sl8p Will not turn on
15 in
Initial turn on the back light comes on just enough to see. When pressing the power button a 2nd time the back light blinks off for a moment and the it comes on again as before. Unplugginf unit is the only way tur turn it off.
I have 2 units failing the same way.
    Master:
  • 521 Answers
In the power supply board there is a capacitor which supports the power ON/OFF button is faulty.just get it replaced.it will work properly.also check the timer.
Posted on Aug 23, 2008
  • 1,800 Answers
Its a problem with ignition panel try to change ut its not an easy task though.
I need code for lm1075 universal remote on a Sylvania tv
Press the power button and the button for the device to be programmed, holding them down until the red light comes on. Release the buttons at the same time. Pointing the remote at the device to be programmed (while the device is on), press the PLAY button. The red light will flash 10 times as it Foss through ten codes. If the device turns off, press the REWIND button once every few second until it turns back on. As soon as it turns on, press the STOP button. You May have to go through several sets of the ten codes to get to the right one. Press the play button after each set of ten if you haven't had tor device turn off. After you have the device coded, hit the device button, then power, to make sure you have it programmed. Good luck. I just had to do this myself. I had memorized how to do it, threw away the manual, then forgot. I couldn't find any help online, so I played with it until I figured it out.
May 06, 2015 | Sylvania Televison & Video
Sylvania plasma tv will not turn on
power supply board has defective components,check for swollen capacitors and replace them,if problems still not solve email me at rspoliah@gmail.com .for further instructions
Aug 14, 2014 | Sylvania 6842THG 42 in. Plasma HDTV
Looking for a solution to an error 6502 on canon printer mp510
turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be releasedbefore doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Jul 25, 2011 | Canon Office Equipment & Supplies
My remote broke and some of my channels are on sap. and when i go to the menu there is no audio setting how do i put the channel setting back to stereo or mono
Hello
While receiving an MTS broadcast, press [Audio] repeatedly to to cycle through the available channel.
Main: Outputs main audio.
SAP: output secondary audio programme.
Mono: Outputs mono audio.
You must ahve remote control to change these, because only remote control have Audio button on it to control these. OK.
May 05, 2011 | Sylvania LC-155SL8P 15 in. LCD Television
I have a dish network satellite dish and the remote control codes don't work for my sylvania lc320ss9 lcd tv. Are there any codes that will work?
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the TV Mode button on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Jul 04, 2010 | Sylvania LC320SS9 32 in. LCD TV
My tv does not power on and I also have checked the remote/batteries and tried unplugging and plug back in and it still does not work. It is a Sylvania 32inch lcd tv #6632LG
When you press the power button do any front panel lights come on? If so, turn out all lights and then turn on the tv. See if you can barely see a picture or any light in the background. LCD tv's work about the same as conventional flourescent lighting. Each light has a ballast (transformer) and when it completely charges up you have light. When the transformer starts to go bad you get flickering of the light or no light. On LCD tv's you can find capacitors on the power supply that when they charge up the back lights power on which shows the picture. If the capacitors are too weak or shot then the back lights do not come on leaving the screen dark. If this is your problem take it to a repair shop or have a technician come to your house and fix it. Hopefully this is all it is. You can also try to hold your power button in for about five to 15 seconds to see if the tv resets. How old is the tv?
Mar 05, 2010 | Sylvania 6632LG 32 in. LCD HDTV
Just bought HPJ4550 and will not turn on during initial setup. Appears to be power to the cord as the green light is on on the coverter.
Ok. The most obvious things first. Unplug the power from the printer itself and plug it back in. Next, press the power button just 1 time and wait 10-15 seconds. If you do not see any lights or display, try a different outlet. If you still cannot get a response from the printer even after trying a different outlet, the printer or power cord is defective.
Aug 22, 2009 | Office Equipment & Supplies
Programming the remote
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Oct 22, 2007 | RCA RCR412C Remote Control
Televison & Video Logo
Top Televison & Video Experts
