Question about Sony Cyber-Shot DSC-T1 Digital Camera
BLACK VIEWER SCREEN WHEN IN CAMERA OR RECORDING
WHEN I OPEN MY LENS IT SHOWS THE SETTINGS BUT IN SINGLE PICTURE MODE AND RECORDING MODE, AND THE BACKGROUND IS BLACK. IS THERE A SETTING I NEED TO CHANGE?
MELLIE
  • 10,594 Answers
Your DSC-T1 has problem with CCD Imager and Sony will repair it free of cost. Please click Sony website and confirm camera symptoms and get details to proceed further.
Regards,
Posted on Aug 24, 2008
My powershot A540 shows a black screen and takes blank photos. Something between the viewer/card and the lens is closed and only opens occasionally, no matter how much I fiddle with the settings.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 04, 2011 | Canon PowerShot A540 Digital Camera
The screen on My Canon Power Shot SX 120 IS camera will not show any images when I turn it on. It simply shows black, if I take a picture, the picture will record on the memory card but it is also just a...
Nov 18, 2010 | Canon PowerShot SX100 IS Digital Camera
Camera opens normally, only takes black pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 09, 2010 | Canon PowerShot A530 Digital Camera
The viewer is black.
Mar 29, 2010 | Canon PowerShot S2 IS Digital Camera
Seems to be o.k. with sounds and menu screens,but no image of pic shows in viewer,and no image is recorded when transferred to computer
Oct 22, 2009 | Canon PowerShot A530 Digital Camera
Canon Powershot A75 - Camera mode is not functioning
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Sep 18, 2009 | Canon PowerShot A75 Digital Camera
Black screen, black pictures
Set to auto shooting mode, take pictures, if still get black pictures, you need to repalce the lens unit. CCD or shutter defected.
Jul 08, 2009 | Olympus Stylus 720 SW Digital Camera
Shooting mode shows nothing.
I just had this issue with my camera (my 15 year old son solved it for me ;-) ).
The viewfinder was active in "record" mode and the LCD was "active" because you could see a little back light but no image. The "playback" mode would let me review pictures in the LCD though so I know it is capable of showing information.
If you push the display key/button a couple of times you can see the picture move from the viewfinder to the LCD and have just a picture and or a picture and information.
So try setting the camera to "record" mode (lens comes out) and then push the "display button" which is on the back of the camera just to the right of the LCD on the lower right side several times and see if the LCD starts to work.
It could be that somehow the display button was pushed by mistake.
Bill
Dec 07, 2008 | Canon PowerShot S3 IS Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black
The camera is fine. Since it is an Single Lens Reflex (SLR), it is not possible to use the LCD screen to compose your pictures. Canon answers that here: CanonUSA
Click on the frequently asked questions
Jan 19, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Sony Cyber-Shot DSC-T1 Digital Camera Logo
65 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
