Question about Belkin Computers & Internet
I have connected my Wireless G Router #F5D7230-4 to the modem as instructed in the instructors manual and I am unable to obtain a internet connection. I have tried to disconnect from modem and router and reconnect several times but I am still unable to get a connection.
    Problem Solver:
  • 7 Answers
What kind of brand is it? and make sure your ethernet cable pluged in back of router where its supposed to be and reset your modem first when lights start lighting up reset your router...by reseting i mean unpluging power from equipment...hope that helps
Posted on Aug 24, 2008
I dont know how to get wireless internet
Check the ADSL or cable modem status light. If it is solid green, it indicates that your ADSL/cable modem has a good connection. If the light is off, check modem's physical connection.
Verify that the Internet light on your wireless router is solid or blinking green. It indicates a good connection and correct wiring.
When done, log in to the web interface of your router device and check if it can obtain the IP address from your ISP or not.
If you see 0.0.0.0, the router is not obtaining the IP address. It can happen due to various reasons. Contact your ISP and ask for the details including username, password for PPPoE etc. and try to connect to the Internet again afterwards.
You may also need to configure the default gateway settings also. To configure your router device as the default gateway, reboot your PC. When done, open Command Prompt, type 'ipconfig/all' and hit Enter. Check Default Gateway
If you are still unable to browse the Internet, ping your router's connection to the PC.
The Request timed out error can occur due to two things: (1). incorrect physical connection between your router device and the PC or (2) incorrect wireless network setup & configuration. Recheck and correct the Ethernet connection between your PC and the router device.
When done, check back if you can browse the Internet or not.
***If you need any kind of technical assistance you can contact support cell
Jan 21, 2013 | Computers & Internet
Unable to obtain valid IP config
Unplug power to ISP modem, till you see it reboot. Test with a cable to establish you can connect directly with ISP modem. If OK, reconnect with wireless modem. You will have to switch between wireless and regular network adapter on laptop for this test.
Use these instructions to test and see IP's.Go to Start > Search > Type cmd and hit enter key.
In Command Shell:
Type ipconfig /all These are your IP settings.
Type ipconfig /release To clear IP settings.
Type ipconfig /renew For new IP settings.
You will need to check NIC drivers in Device Manager if problem persists.
Oct 02, 2012 | Gateway M Computers & Internet
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
I canot connect to the internet but my laptop detect my router
Make sure your modem is plugged in, first and foremost.
Make sure your modem is connected to your Router with the Ethernet cable.
If you're unable to connect still, do a reset on both the modem and the router at the same time. Unplug both, wait for 30 seconds and plug them back in again.
If you are still unable to get an internet connection, right click your wireless connection in the toolbar on the bottom left (Assuming you're using a PC). Click "diagnose" and it will run through your connection, to identify the problem.
Follow the instructions on screen.
If you are still unable to get a connection after trying these, contact your ISP and have them reset the modem and walk you through wireless setup for their particular system.
Thanks!
Hope this helped!
Jun 03, 2011 | Computers & Internet
Linksys WRT150N is connected to the internet via cable modem, but the wireless router shows no internet connection and I am unable to log into teh router manually?
Reset the router for 30 seconds. Then power cycle the router and modem.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Sep 01, 2010 | Linksys Wireless-N WRT150N Router
Trying to Install a wireless router WRT54GS; ISP Cox Cable
I don't know what type of internet connection you have. If you have cable internet connection, you can copy the mac address of your modem to your router - that's what you call, cloning. If you have DSL connection, you can just obtain an IP Address from the modem to the router. If it's an Internet connection that is requires authentication, you can use the PPPoE type of connection. You can configure your router to any of the mentioned configuration above.
Feb 14, 2010 | Linksys Wireless-G WRT54GS Router...
No internet connection
When connecting the devices make sure that you turn on the device in this manner: modem (wait for the lights to be solid) then router, then the computer.
Check if you can get online, if not then follow the steps below:
1. Open a web browser and type this in the address bar: 192.168.1.1
2. Then you will be in the setup page of the router. You need to know what is your connection type obtained from your ISP.
If DHCP, internet connection type should be: Automatic Configuration - DHCP should be selected.
If PPPoE, select PPPoE and type the username and password provided by your ISP.
3. Then save the changes.
Once that the internet connection is working from the PC hardwired connected to the router, then check the wireless settings under the wireless tab. Take note of the SSID, wide channel, and the wireless security and preshared key.
Put those settings on the wireless adapter of the laptop and you should be able to get online.
I hope this works! Good luck!
Dec 11, 2009 | Linksys WRT160N Wireless Router
My laptop indicates that I am connected to my wireless connection but I am unable to connect to the internet. Any advice?
Has your wireless router/modem been configured to your ISP's instructions.
You should also contact your ISP to get them to test the connection to your router/modem especially if you have a DSL modem.
Sep 20, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Not able to install the software, tells me mdm.exe has stopped working and won't go any farther
Manual Setup: This option is best if you cannot use the wizard on the CD, are replacing an
existing router, or are technically knowledgeable. Follow the instructions in this manual to set
up your router.
Connecting Your Router
1. Connect the router, the computer, and the modem.
a. Turn off your computer.
b. Turn off and unplug the cable or ADSL broadband modem.
c. Locate the Ethernet cable (1) that connects your computer to the modem.
d. Disconnect the cable at the modem end only (2).
e. Securely insert the free end of the cable (1) into a LAN port on the router, such as LAN
port 4 (3).
f. Securely insert the yellow cable (5) that came with your router into the yellow Internet
port of the router (4) and the other end into the modem (2).
Setting Up Your Router for Internet Access
To access the router using its login name and password, follow these instructions.
1. Connect to the router by typing http://www.routerlogin.net in the address field of your
browser, then click Enter.
For security reasons, the router has its own user name and password. When prompted, enter
admin for the router user name and password for the router password, both in lower case
letters.
Enter the user name and password. The router will display its home page.
When the router is connected to the Internet, click the Knowledge Base or the Documentation link
under the Web Support menu to view support information or the documentation for the router.
If you do not click Logout, the router will wait 5 minutes after there is no activity before it
automatically logs you out.
Set Up and Test Basic Wireless Connectivity
Follow the instructions below to set up and test basic wireless connectivity. Once you have
established basic wireless connectivity, you can enable security settings appropriate to your needs.
1. Log in to the router at its default LAN address of http://www.routerlogin.net with its default
user name of admin and default password of password, or using whatever LAN address and
password you have set up.
2. Click the Wireless Settings link in the main menu of the router.
3. Note that the default SSID is NETGEAR.
4. Set the Region. Select the region in which the wireless interface will operate.
5. Click Apply to save your changes.
6. Configure and test your computers for wireless connectivity.
Program the wireless adapter of your computers to have the same wireless network name
(SSID) as the router. Check that they have a wireless link and are able to obtain an IP address
by DHCP from the router.
Note:
Apr 19, 2009 | Computers & Internet
Unable to connect a WGR614 Wireless Router to a DM111P Modem
Sounds like you need to port forward your router. Go to port forward .com. find your router and follow the instructions. Hope this does the trick for you.
Nov 26, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
