Question about Car Audio & Video
My boat stereo stopped working, it makes a slight popping sound every few seconds
Did you ever figure this problem out? the same thing just happened to me?
Posted on May 15, 2010
How to fix a rc boat that works out of water but not in
change the esc its been wet and caused a electrical short. its almost cheaper to buy another zig zag or a totally different boat rather then repair that one.
Dec 31, 2012 | Hobby Zone Hobbyzone Zig Zag Racer 3...
My Pioneer car stereo stops all audio signal after a couple of minutes regardless whether i'm playing a CD or the radio, but the stereo stays on. and the CD seconds and minutes still count, do you know why...
Check your connections to your speakers and amp and look for loose wires touching metal. I believe your stereo is fine, this has something to do with your speakers and the speaker wire
Jun 07, 2010 | Pioneer DEH-P6400 CD Player
I bought a boat with a clarion cd/stereo head unit. I noticed a problem while trying to play the radio that the speakers continually cut out. I get music for 2-3 seconds, then a popping sound, followed by...
try taking antenna lead out of set and put a length of wire into the center hole were the antenna fits then scan,you should pick up at least one station,if you do fit a new antenna,if not try switching off any traffic anouncement services on the set ie press and hold button marked either ta/rds/tta/ast
Topspark
Aug 21, 2009 | iLO XM-MP3-CD Car Stereo
I have a jvc system on my boat. It worked fine
Check all the wiring for the speakers. It is grounding out somewhere. I had the same problem with my kenwood in my truck. Its grounded most likely to itself if its a fiber glass boat.
Jul 08, 2009 | Car Audio & Video
FM Reception with Jensen MSR3007
I have the exact same problem with the exact same stereo. I started by removing the in-line AM/FM/VHF Separator and connecting the antenna directly to the stereo. The static/popping/fade-out continued. Today I swapped to a new antenna, but it did not help. I swapped back to the original antenna and for a brief while, I had good reception. The I went to coil the excess antenna cable and the static/popping/fade-out resumed. I have narrowed it down to either the antenna connector coming out of the back of the stereo or an internal circuit. Either way, it does not look like a do-it-yourself fix.
May 31, 2009 | Jensen CD400M CD Player
Stereo display works fine, but no sound to speakers.
The wires may have gotten wet and fried something in the sound output in the stereo.
Jun 16, 2008 | Pioneer DEH-1900MP CD Player
Do I need a new equalizer?
Karla, Equipment and water especially SALT water (AND SALT AIR) don't mix very well. The constant high moisture environment affects all the connections (the wires) the rca connectors (where one thing plugs into another, AND the switches. The wires may LOOK good but the connections may not be. When you say "all seems to be in good condition" tell me specifically how you checked them. Sometimes they LOOK good, but ar not making connection. While your stereo is ON, get in there and wiggle everything and see it the speakers come back on.
My first guess is your amplifier/reciever. Does it have speaker switches? If it does, move them up and down or click them many times to see if you can work the corrosion a little. This may help.
I'll try and help, let me know some of the stuff I've asked fo above.
Feb 22, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Clarion Xmd3
Bottom line is that boats are a hrsh environment for electronics. Moisture, salt, and vibration all conspire to undo solder joints and electrical connections. 4 years is a pretty good life span on a boat. A solder connection within the unit could have let go. A good repair shop could probably fis the bad connection but you can probably replace the unit for less.
Jun 26, 2007 | Clarion XMD3
Boat stereo/speakers
Wonder if the return line from both speakers was wired to a common earth, and you've lost that connection? If that happened, you'd end up with the two speakers in series instead of in parallel, and just playing the difference between left and right channels (so very much quieter). Check also the stereo doesn't have a separate fuse (possibly internal) for the power amp stage. A.
Mar 30, 2007 | iLO XM-MP3-CD Car Stereo
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
