Question about Cameras
I just came into possession of a Minolta Model SRT 102 Old camera. The camera has several lenses and one is attached-i dont know how to take the lens off the camera body, can anyone give me instructions to do this? thanks, Paul
  • 876 Answers
I don't personally know this model. Do you see some little clips along the inside rim of the lens? On some cameras you simply push in the little clips and the lens comes off/on others you unscrew it. Is the lens on the camera a minolta? If not there may be a lens adapter on there as well. Read on each little ring and tell me what they say. and in the meantime I'll try to find more info on your specific camera.
Posted on Aug 23, 2008
Cant find the batteries for the cam
It uses a 2CR5 battery, which should be available at most electronics or office-supply stores. An online source is at http://www.batteriesplus.com/product/31018-RAYRL2CR5--1-Lithium-Battery/563-0/4739-Film-Camera-Battery/56279-Minolta/Maxxum-400si.aspx
It has a Minolta A-mount lens. Any of the newer Minolta (and some Sony) lenses may be used. The older Minolta lenses for the SRT-series cannot be used.
Nov 26, 2013 | Minolta Maxxum 400si 35mm SLR Camera
X370
There are adapters available to fit the old Minolta manual-focus lenses on Sony alpha-series dSLRs as well as Sony NEX-series interchangeable lens cameras. The lenses obviously will not autofocus and, depending on the lens and camera body, you may lose some or all exposure metering capability.
Nov 26, 2012 | Konica Minolta Minolta 110 Zoom SLR Mark...
Can't change f-stop to higher numbers
That tiny silver post on the front of the body moves the pointers inside the body so you can see in the viewfinder where the aperture is set. It should move far enough that it lets you set 1.7 to 22. Check it to be sure the internal display matches the lens setting.
If it matches, and won't let you go all the way over, check the track for obstructions. Remove the lens and check the silver tab. It should go past the A in MINOLTA. Does the tab move all the way with another lens?
It sounds like something internal is blocking the movement of the ring or its linkage on the SRT.
I suggest a trip to the repair shop for the SRT. Garry Airapetov in Niles, IL repairs them at a very good price. He will fix it, clean, Lube, adjust it, and return it for around fifty dollars.
Look up Garry;s camera repair online to check prices and download the form you send with it.
He did a really good job with my SRT 101.
lightspiritphotography.com
Dec 10, 2009 | Cameras
I have a minolta 7000i non-digital camera with several nice lenses. Are any of these lenses compatible with any new digital cameras?
I am pretty sure that your lenses are just fine for your Digital camera(Minolta or Sony only) as they have the same lens mount. I you choose a KM5 or KM7 digital cameras your lenses will be longer by a factor of 1.4x, same goes for Sony cameras except A850 and A900. They will give you the same magnification ratio as your 7000. Minolta was sold to Sony several years ago, and they have been building a great reputation since. Your AF maxxum lenses will work great on any KM or Sony camera(ADI is available on distance integrated Minolta maxxum lenses only. You can tell by looking at a lens marking which will say "D" if it is compatible with distance integration). I find distance integration an extra not a necessity. If you have some great glass that you love and hold dear, then it would be a great idea to buy Sony. Note that another answer by miket756 is mostly wrong. Yes your lenses will get longer on APS sized sensors, but a 28 mm will never become a 150mm equivalent(thats just stupid). It will look more like 40-50mm on APS-C camera. If you got 2000-2700$ for Alpha850 or Alpha900 than your lenses will retain their mag factors. Good luck.
Oct 26, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Sigma 70-300 +''no lense attached'' w/ sony a200 dslr
clean brass contacts with qtip and rubbing alcohol. let air dry couple of hours. do the body and the lens. hope that helps
Jun 02, 2009 | Sony Alpha DSLR-A200K Digital Camera
Used on a Minolta Maxxum 800 si
Hello
The Minolta AF lens will fit and work on most of the Minolta AF bodies (it will depend on exactly what lens it is as to the compatibility), you will also find that it will fit and work with the new range of Sony
digital SLR camera bodies.
The Quantaray lenses are a little bit more difficult as Quantaray make lenses for several different types of camera body, it should mention on the lens what make the lens mount is for. If you post further information about the lenses it might help.
Sep 19, 2008 | Quantaray 100-300mm F4.5-6.7 Zoom lens for...
Minolta 7000 Maxxum
The Minolta Maxxum 7000 uses a Minolta A mount, which is also used on the Sony Alpha series, as they bought out Minolta's technology. All Maxxum lenses should work for the most part on the Sony Alpha series of DSLR's, including the autofocus.
-John
Sep 15, 2008 | Tamron 28-300mm f/3.5-6.3 XR Lens for...
Minolta 7000 SLR
The Konica-Minolta 5d, and 7d, both discontinued but available used on ebay and other places will work with your AF lenses, as well as all the sony alpha camera bodies. KM sold their camera business to sony, and most of the whole maxuum/alpha/dynax group of engineers went with the sale to Sony. I had a 7000, and an 8000i, and all my lenses are quite happy on the 7D I picked up a few months ago on ebay.
Mar 27, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Minolta Maxxum HTsi plus
Minolta Maxxum lenses fit certain Sony digital cameras. Check this site as it depends on the specific model.
https://feltmagnet.com/photography/Digital-SLR-Cameras-and-Those-Film-Era-Lenses
Aug 20, 2017 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Cameras Logo
97 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
