Question about Cameras
Where can I locate a company who could sell me a shutter part # 208-DB3015-0000 for a Megxon C480 Camera? On the Shutter which it also reads AX480 Shutter BD Rev. 00
WHATE IS THE PROBLEM OF (AF NOT CALIBRATED)APPEARS IN SCREAN OF (AX480)CAMERA
Posted on Aug 27, 2012
  • 11967 Answers
SOURCE: camera has gone off and shutter and lens wont
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 06, 2010
SOURCE: Megxon c480
I hit mine with a hammer It works well again now.
Posted on Aug 15, 2008
jackboy
  • 2985 Answers
SOURCE: Megxon C480 Digital View Camera
I regret that there is no repair option in general for this type of thing.
Replacement is the only option
Posted on Jan 02, 2009
  • 21 Answers
SOURCE: Zoom does not work on Megxon C480 does not allow focus
what is the screen say is happening
Posted on Jan 03, 2009
SOURCE: Manual Needed for Megxon C480
http://www.tekxon.com.tw/E/techsupp/download/C480/C480%20Manual-EN.pdf
Posted on May 07, 2011
Shutter gear sound
The shutter in this camera does not have gears. Gears are used for film transport and cocking the shutter. Nikon stopped selling parts last year so unless you can find them on eBay you are pretty much out of luck.
you can get to the gears by removing the bottom cover.
Dec 06, 2013 | Nikon F60 35mm SLR Camera
Shutter won't reset after battery replacement
it can fixed only camera fixera company,better if you fix it according to camera company because your problem also be facced to me,i take it to a ordinary camera fixer and then my camera fully get damaged because who fixed my camera they fall acid in battery placce.
Mar 26, 2013 | Vivitar V3800N Zoom 35mm SLR Camera
HOW DO I ADJUST THE SHUTTER SPEED
You cannot change the shutter speed on your camera. If you want more control over shutter, aperture, etc. you must spend more money on a better camera from a better company. Vivitar makes cameras for the novice and they are as simple as can be. Sounds like you're ready to expand your photographic horizons.
Jun 09, 2010 | Vivitar ViviCam 5385 Digital Camera
Shutter button popped off
If you do a search for "sony h2 shutter button replacement" on Google.com you will find a shop that sells both the shutter button and a repair service to install the shutter as well.
Hope this helps!
Jul 06, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Shutter stays closed on bronica 645 etr medium format
Have the electronic shutter checked by a repair shop. Sounds like your Seiko electronic shutter has died or there's a short somewhere between shutter and lens. Hope this helps.
Fotobean
Jan 15, 2009 | Bronica ETR-Si Medium Format Camera
Jan 02, 2009 | Cameras
Jan 01, 2009 | Cameras
Megxon c480
Apr 08, 2008 | Cameras
Shutter trouble pentax ZX-50
why is most camers that are run by batteries do not last any length of time, i am about to report this to wnct trouble shutter yo see if the camers are dezine to run batteries down , to sell more battiers , whitch means that the camer company is in cohoops with the battier company , witch come be a law suite fog all cammer owners by elvin pender ph 919 242 4031
Nov 17, 2007 | Pentax ZX-50 35mm SLR Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
