Question about Panasonic PT-50LC13 50" Rear Projection HDTV
How to reset the meter of lamp
I got Panasonic Tv pt43lc14 and got lamp changed a fwew month ago, ty-la1000. The picture is clear and the message on tv appears as " the lamp need to be replaced and lamp hour meter need to be rest"
I do not have the owners manual, please help me to reset the meter. Thank you
Jay
  • 3 more comments
  • gub59 Sep 06, 2008
    Same problem as described on a Panasonic PT43LC14, but the intended fix did not work. I have had this problem for months. Another site said to unplug the TV for a few minutes then plug it in again. Still no luck. Any other solutions?
  • jadehart9 Oct 05, 2008
    After lots of roaming the message boards on this, I figured out that although I have the PT-50LC13 model, for some reason the remote I have is for the PT-50LC14 model. Naturally, now I cannot reset the lamp timer (the PIP button doesn't exist on my remote and the SPLIT button does not work for this model). Is there any other way to reset the lamp timer?
  • veronicakilr Nov 01, 2008
    I need to reset my tv after the bulb is changed what do I do?
  • Anonymous Feb 16, 2009
    replaced bulb need to reset timer
  • Anonymous Feb 25, 2009
    can not finh the lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Posted on Sep 04, 2008
  • Bob Gillihan
    Bob Gillihan Jan 30, 2014
    Meter failed to reset per these instructions; suggestions?
Thanks this fix helped alot. I had already replaced the bulb but knew nothing about the timer so reseting this timer turned off the light. Thanks once again.
Posted on Sep 03, 2010
  • Barb Bish Oct 16, 2011
    Does anyone know how to reset the timer when the picture doesn't come on (black screen)?
  • Bob Gillihan
I have a large screen panasonic tv. The lamp
Turn On tv.
Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
Hope this info will help you.
Thanks.
Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
PT-52LCX65 Lamp Meter
Hello.. meseta809
first off all it's not necessary to have the TV on to reset it. the problem is the dmd need to send the info that you have a working lamp.
try this to see if it work's
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Ok, so apparently there are a couple of different ways forum members have found out how to reset their Panasonic Lamp timer (this should apply to all of them, not just the TY-LA1000 specific lamp)
“Hold the VOL down button on the TV and the SPLIT button on the REMOTE for five seconds”
Again, you will need to press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds, it will NOT work if you try to do it both from your remote!
Jan 15, 2010 | Panasonic PT-52LCX65 44" HDTV
After just recently replacing the bulb I am
Here is proceudre to reset lamp timer in your TV..
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen message ' lamp time was reset to 0' will appear.
Thanks.
Nov 18, 2009 | Panasonic TY-LA1000 Projector Lamp for...
Set timer
You did not post model number of TV so try below method to reset lamp timer.
Turn TV ON, Press and hold Volume minus button on TV and press Split/ Play button on remote for 6 seconds, lamp reset message will appear on TV screen.
Jul 02, 2009 | Panasonic TY-LA1000 Projector Lamp for...
How do you reset a lamp hour meter in a panasonic TV
hold volume on TV (-) down and (0) zero on remote for five secs..
Jun 30, 2009 | Panasonic TY-LA1000 Projector Lamp for...
I have a panasonic model pt-52lcx15 and replaced the lamp part # ty-la1000. It works fine but I can't figure out how to reset the timer, do you have instructions for this, they weren't included with the...
Hi, I have the fix for you....EXIT out of the message telling you to reset you meter. Now you need to push the - vol (neg vol) button on you set, at the same time push the split button on your remote (very bottom of the remote is the split button with the vcr controles) You need to push these at the same time for 20 or more seconds and you will recieve a message that the metter has been reset. Exit out of that message and all should be fine. Took me about 15 minutes to get to a tech to walk me through it.
Jan 18, 2009 | Panasonic TY-LA1000 Projector Lamp for...
Panasonic TY-LA1000 has good lamp, but black screen. light is blinking green, then solid green, then after some time goes red?
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
Jan 11, 2009 | Panasonic TY-LA1000 Projector Lamp for...
Panasonic lamp
Brian, I just helped my buddy replace his Panasonic ty-la 1000 bulb this weekend. I have to tell you that I have a complete illiteracy when it comes to electronics but we got it done in about twenty minutes and were watching it again. Looks great. We ordered the bulb from dlp lamps.com and had it in about two days. They also had super easy instructions to follow. Try it before you replace the entire TV.
Sep 07, 2008 | Panasonic TY-LA1000 Projector Lamp for...
Set lamp timer
Jerico, If you will go on dlp lamps .com I believe they answer that question in their FAQ. You can also give them a call. Look on their site for number. All I know is that they make the whole process really easy.
Jul 11, 2008 | Panasonic TY-LA1000 Projector Lamp for...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
3,923 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
