Question about DeLonghi Pinguino PAC-02 Air Conditioner
Delonghi pac-02 a/c
Pac-02 does'nt blow cold. any quick suggestions to fix (perhaps a simple recharge-and how)?
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Posted on Sep 06, 2008
Purchase unit used and worked fine for a day then it would only blow cold air for 3 minutes and hazard light would come on. So I had to press the red reset button on back on unit. Again only blew for 5 minutes and it shut off.
Solution: Clean Sensor.
1. Unplug the unit.
2. Unscrew the back metal wall.
3. Cleaned off the dusk & sensor (a copper rod, upper top left of unit).
(Make sure clean & dry.)
4. Replace metal back onto unit.
5. Plug it up & turn unit on, it should work.
Mine did not work the first time so I waited 24hrs then I turn it on and it's been working ever since. I think maybe it was the sensor might have had a little due on it, but after 24hrs it was completely dry.
Good luck.
Posted on Aug 16, 2012
Y my Delonghi Pinguino PAC O2 doesnt blow cold air no more
Posted on Aug 02, 2009
How do i recharge the gl-pac-08e4
needs to be recharged by a trained technician
Aug 04, 2014 | Soleus Powered by Gree Powered by Gree...
I just bought a used DeLonghi Pinguino PAC 02. It seems to cool ok but the exhaust hose gets very warm. Is that normal?
Yes, that is normal. It's exhausting the heat from the compressor out the window.
Thanks for choosing FixYa.
Sep 09, 2011 | DeLonghi Pinguino PAC-02 Air Conditioner
Does not blow out cold air. It comes on but does not blow out cold air, only has cool air
My DeLonghi PAC L90 Portable Air Conditioner does not blow out cold air,only has cool air
Jul 12, 2011 | DeLonghi PAC L90 Portable Air Conditioner
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Pinguino ct 90 trips the circuit breaker and soaks the carpet....
My Delonghi Penguino ct90 no longer blows cold air out for longer than a couple of minuets need a fix for this and it is no longer under waranty. Please help.
Jul 05, 2009 | DeLonghi Pinguino PAC-700T Air Conditioner
Exhaust Hose DeLonghi PAC-210U replacement
Hi
You need to go here
://www.delonghi.co.uk/accessories.php
Feb 14, 2009 | DeLonghi Pinguino PAC-02 Air Conditioner
Delonghi PAC 02 A?C
http://www.delonghi-accessories.com/item.asp?modelnumber=9824000005
or call 1-800-865-6330 and order over the phone. I just did, $65 including shipping for ONE exhaust host.
Jul 07, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Pinguino pac-166 not cooling enough
CHECK AND CLEAN THE DUST FIELTER AND ALSO CHECK THE BLOWER THEN TRY IT
Jul 06, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
DeLonghi Pinguio Pac 45
1. Clean air filer every 2 weeks.
2. clean ACCU and FCU every 3 months.
3. check and re-tight all electrical connection every 6 months.
Jan 10, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
DeLonghi Pinguino PAC-02 Air Conditioner Logo
1,154 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
