Question about Compaq Deskpro EP PIII-650MHz/ 128MB/ 10GB/CDROM/ FDD/ ENET/ Keyboard/ Mouse/ WIN98COA/ No OS - (CODEEPPI1210) PC Desktop
Lost driver thro error code 39 dvd/cd rom drive
  • 43 Answers
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver fro this hardware. The driver may be corrupted or missing (code39)".
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely resolved your issue. Good Luck!!!!
Thanks
Posted on Sep 18, 2008
    Scholar:
  • 47 Answers
Dear sir/madam,
you can solve this by using the following links,
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
http://www.vistax64.com/vista-hardware-devices/113566-cd-dvd-rw-error-code-39-a.html
thank you,
Posted on Aug 23, 2008
Drive not showing in WinXP (error code 39)Liteon Combo SOHC-5236v
After loading the Windows, the DVD/CD-ROM drives work properly, but we can not see the drives in “My Computer” (System can not recognize the drives.). When try to run the drives, it shows up a notice “Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code39).” Before solving this error, check the drives connection correctly, then follow the steps below:
Delete Device Manager. Most people will firstly think of Windows “Find New Hardware” when drives missed, but it does not always work out. To fix the problem: open “My Computer”’ “Control Panel” ’“System”’“Device Manager”’ “HDC(Hard Disk Controller) ”, then click “Delete”. Follow the note to reboot computer. After rebooting, the computer will find the Primary IDE Controller and Secondary IDE Controller again and install the drivers. Restart the computer again while the installation is completed. In this, we can get back our CD/DVD-ROM Drives.
The other way is by editing the registry to return the missed CD/DVD-ROM drives (Code 39 error.). Obviously, it is too risky to edit the registry if you are not familiar with it. To fix the error from the registry, carry out the following steps:
Exit and close all applications currently running on your PC.
Step1. Click Start > Run and type in Regedit, press Enter.
Step2. Look for the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
Delete any of the following registry entries under this key directory:
LowerFilters
LowerFilters.bak
UpperFilters
UpperFilters.bak
Step3. Reboot your PC and open My Computer to check that the CD-ROM drive is visible.
Also, have a look at the Device Manager to see if the yellow exclamation mark and the error code 39 are gone.
System errors are not welcome guests that bring up unhappy computing experience. Registry Easy (www.registryeasy.com) is a professional troubleshooting system maintenance tool that can help you to solve this error and many more.
Article Source: How to fix DVD/CD-ROM drives (Code 39 error) in Windows XP or Vista
Posted on 2 January '09 by , under TECH NEWS.
This worked for me.
Feb 12, 2009 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
Need toshiba dvd/cd drivers for laptop
hey,
the drivers come with windows, you shouldn't need a driver.
If you look into device manager and the drive has a error code about driver, for example code 39
have a look here
http://www.fixya.com/support/r548399-fix_non_working_cd_dvd_shows_in_device
Jan 19, 2009 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
! on my LG GCC4522B CD-RW/DVD-ROM
To solve this Code 39 error, follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Nov 21, 2008 | Computers & Internet
DVD/CD-ROM DRIVES driver may be corrupted or missing. (Code 39)
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Another possible CD/DVD issue you may want to investigate
Oct 12, 2008 | Computers & Internet
Compaq Deskpro EP PIII-650MHz/ 128MB/ 10GB/CDROM/ FDD/ ENET/ Keyboard/ Mouse/ WIN98COA/ No OS - (CODEEPPI1210) PC Desktop Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
