Question about Magic Chef CAV2000 Top Load Washer
Washer magic chef
My washer started to not wash it will spin and rinse but not agitate. What can I do ?
W2225lv
Posted on Nov 01, 2008
I have a magic chef 20 lb capacity heavy duty washer model W20HN3S serial ME851474 with spin problems. Clothes come out soaking wet. Can I replace a belt?
If your washer will wash (agitate) your clothes but does not spin well, you will need to replace the "thrust bearing" in the washer. The repair is simple and will only take you a short to do. Here is a link to the "thrust bearing kit" you will need.
Jan 07, 2011 | Chef Cooking Magic Chef Washing Machine...
Margic Chef washing machine makes loud ginding noise when agitating and on the spinning cycle.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Magic Chef CAV4000AWW Top Load Washer
MAGIC CHEF WASHER WONT SPIN OUT
underneath the washer is a pully assembly kit . remove the belt ,the c clip and replace the pully kit about $ 20.00 cost for parts.
Feb 02, 2010 | Magic Chef CAV4000AWW Top Load Washer
Magic Chef 20lbs hd won't agitate
Try these
  1. Test the lid switch
  2. Inspect the motor coupler
  3. Inspect the drive belt (belt drive only)
  4. Inspect under the washer for soot (clutch)
  5. Test the motor
  6. Inspect the pulley
  7. Test the transmission
  8. Inspect the agitator
  9. Inspect the pump coupling
  10. Test the water level switch
pls rate my suggestion.......
Jul 23, 2009 | Magic Chef CAV2000 Top Load Washer
Wont do spin cycle
sounds like a timer problem. contact a wholesale applaince parts distributor such as First Source. They will be more than happy to help you. You will need to provide them with make and serial no.
May 14, 2009 | Magic Chef CAV4000AWW Top Load Washer
Magic Chef Clothes washer model CAV2004AWW
Something locked up on the transmission then the drive belt broke. Put on a new belt and try a spin cycle, if it works but it won't agitate then the trans will need replaced.
Feb 28, 2009 | Magic Chef CAV2004A Top Load Washer
MAGIC CHEF 5 YRS OLD WONT AGITATE
Ours started doing the very same thing. I took the top off and found that a mouse had chewed a hole in the vacuum tube. I replaced it with a 3/16" ID small engine gas line hose I bought at local implement dealer. Works like a charm.
tjn
Jul 23, 2008 | Magic Chef CAV2000AWW Top Load Washer
Washing machine turns off frequently
Your motor is overheating and the sensor is switching it off you need to take it for a sevice
Apr 05, 2017 | Magic Chef CAV2005A Top Load Washer
Magic Chef CAV2005AWW makes a noise in agitate cycle
Sounds like a problem in the gear case. This would be a transmision replacement.
Dec 07, 2007 | Magic Chef CAV2005A Top Load Washer
Washing Machine Won't Spin/Drain
Apparently, there is an issue with this model. Get it checked out. I did.
Jul 31, 2007 | Magic Chef CAV2005A Top Load Washer
Magic Chef CAV2000 Top Load Washer Logo
160 people viewed this question
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
