Here you will find the tips for taking better photos with less camera shaking.
Tips
1. Composing and holding the camera with less camera shaking. For clearer images, hold the camera firmly not to cause camera shaking. 1) For maximum stability, hold the camera firmly well over the grip and keep your right elbow lightly pressed against your body.
2) Support the lens or the camera body with your left hand from below.
3) Look into the optical viewfinder as if pressing your forehead to the camera.
4) Do not stand straight, but with one foot stepping forward for taking better balance of your body.
2. Change the composing and holding the camera according to the situation for securer photographing. (Particularly when you take photos using the LCD monitor.) 1) Lean against the wall.
2) Put the camera on a fixed object like a table.
3) Ensure the camera holding by pressing the elbow against the handrail.
4) Use the tripod.
3. Move the zoom control towards wide-angle if your camera has the zoom function. Moving the zoom control towards tele-angle, camera-shaking will easily happen. If your camera has the zoom function, we advise you to take photos by zooming towards wide-angle.
4. Higher shutter speed will produce better images. Slower shutter speed may produce more possible camera-shaking. If your camera has a choice of shutter speeds, we advise you to select higher shutter speed for less camera shaking.
A "friend" dropped my ixus 50 on xmas eve. I can turn it on and view pictures but the...
(More)
A "friend" dropped my ixus 50 on xmas eve. I can turn it on and view pictures but the shutter will not retract, it moves in and out slightly but stays out when i turn it off. tried a tips page with turning it on whilst holding the take picture button and pushing the lens gently but no joy. guess i have to send to get it fixed? but will cost more than the camera...
When I turn on my camera, it say's CARD IS LOCKED! How do I unlock it? I have moved the little latch...
(More)
When I turn on my camera, it say's CARD IS LOCKED! How do I unlock it? I have moved the little latch both ways and it still says the card is locked, how do i fix this?
canon ixus50 can get menu but when change to camera display goes blank and bleeps then switches its...
(More)
canon ixus50 can get menu but when change to camera display goes blank and bleeps then switches its self off lens doesnot function or the zoom lens doesnotcome out nothing works on the video camera settings
