To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue. 2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM. 3. In the right pane, right-click UpperFilters, and then click Delete. 4. Click Yes to confirm the removal of the UpperFilters registry entry. 5. In the right pane, right-click LowerFilters, and then click Delete. 6. Click Yes to confirm the removal of the LowerFilters registry entry. 7. Exit Registry Editor, and then restart the computer.
I have 40 Neoware 608 thin clients that I need to reset the Windows CE password. I've exhausted my...
(More)
I have 40 Neoware 608 thin clients that I need to reset the Windows CE password. I've exhausted my search on the net. Any help would be great.
where is the wireless radio button on an old HP Pavillion 8705? I just installed a usb wireless...
(More)
where is the wireless radio button on an old HP Pavillion 8705? I just installed a usb wireless adapter and now I'm running the Linksys Add a computer to your wireless network wizard, but the message tells me that my wireless radio adapter in turned off on my computer.
I have owned the Hp Pavilion A808 for many years, with an Acer AL1711 monitor. Last night I rebooted...
(More)
I have owned the Hp Pavilion A808 for many years, with an Acer AL1711 monitor. Last night I rebooted the machine and when trying to log in the wireless mouse and keyboard do not work, I change the batteries and resync several times - nothing. This morning I try to reboot and this time the monitor shows only the splash screen ''Acer'' then it says ''no signal''. I have tried using the monitor on another PC and it works fine, so im guessing I have a computer related issue.
