Product compatibility my lap top does not recognises, many usb devices at times, and demand for the drivers... the problem is even persistent with usb mouse, n pen drives. at times it also demands driver for the finger print sensor which is pre installed with the system.
Sdfgfsdgsgs
Posted on Aug 24, 2008
My computer won't recognise my USB cable (code 43 error)
Its maybe the printer is not compatible with your computer, will to try several steps to determine a solution,
1 try another USB to see if it recognizes it,
2 download and install the driver from the printer manufacturer
3 try another USB device into the same USB port to see if it recognizes it if it does then the USB on your computer works as it should,
if it does then the fault is either software or the printer compatibility.
4 follow step 2 if the problem persist then the answer is your printer is not compatible and will need to order one that works for your system.
Kronoguy
Aug 18, 2012 | Computers & Internet
I am having installing my dynex wireles g usb adapter because it says the install driver is not compatible with windows 7 64 bit. Is there a way to install the driver?
I'd suggest installing the device drivers in the Compatibility Wizard. Remove that hardware device in Device Manager, right-click on the driver executable/installer file and select the Compatibility tab; click the checkbox before Run this program in Compatibility mode for option and select Windows Vista in the list-down box; then try installing the device driver. In addition, you can use the Windows XP driver for testing.
If the problem still persists, please understand that Windows 7 is a new operating system (only the beta version) and whole driverstore has been reprogrammed; some old driver is not compatible with new OS. I suggest that you should wait for another period of time till the retail version is released and push the vendor company to upgrade their device driver. Thanks for your time and understanding!
Good Luck!
Feb 28, 2011 | Dynex Wireless-G USB 2.0 Network Adapter
Cant get the stupid thing to be redognised by vista usb drivers for the mp3 not installed or regnoised
Hi There,               Vista should reconize  it as a usb divice and look into the storage space. Just try to use vista in the control panel and goto add new hardware if ask for driver just but in the software mini cd it came with. I have no problem with mine. If it does not work then you might have a faulty product or you should ask a vista tech how to identify a a usb divice mp4 player to windows. I know the pmp 8308 Missil is compatible with Microsoft Window Vista. It should just be plug and play and identify as a usb device so you can drag and load your videos or mp3s or pictures or even text into your ebook on the device. I hope I helped a bit. Good Luck
May 04, 2009 | Audio Players & Recorders
USB DEVICE NOT RECOGNISED
same problem, solved changing usb cable...even if it is working with different devices...
Aug 02, 2008 | Canon PIXMA MX310 All-In-One Printer
I have a new optical USB mouse but the windows vista on my lap top did not recognise it it sea it but need driver to install it i tried every sing on the lap top to find solution but failed regarding i...
Usually Vista does not need driver to install an USB Mouse.
Try this:
Turn off the laptop, then put the mouse connection. Turn on again. See if now it is working. The mouse should be connected in "off"
If still does not work, try put in other USB port of the laptop. Usually a laptop has at least 2 USB port. Remember to connect it always in "off".
Apr 03, 2008 | Computers & Internet
Photosmart 3310 is on network but not recognized wirelessly
Sounds like another Vista Bug, i would check the HP site for this issue and if its under warranty, contact HP. If you have alot of Blue tooth devices hooked up, it may be that its trying to use another device in its place or the signals are getting crossed, im not positive.
Its like when you have to many network drives all hooked up and you plug in a USB device, Windows pops up those anoying bubles saying its detected, but in My computer it doesnt show.
So bassically you have to right click my computer, manage, disk management listed uder storage, right click on the device or drive and change the drive letter to something like " W" or " Z" or anything not in use.
It may be a siomilar case with your bluetooth, youo may have to much stuff connected. Try redoing everything like you have so many other times before, and then limiting how many bluetooth devices you have connected at the same time. see if theres a difference.
Hope this helps.
Dec 25, 2007 | HP Photosmart 3310 Printer
Iomega USB 2 Desktop Hard drive not recognised by xp sp2
did you set any jumppers to slave? Is it pluged in the right spot?
Nov 24, 2007 | Iomega HDD External Desktop (32660) 80 GB...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
